how many quarts of ATF
Old Nov 10, 2002 | 08:20 PM
maximalover's Avatar
Guys
I want to change the ATF for my 93 Max SE... I got ATF changed last year for $25.00. It is cheap.. I did not know the value.. Now after being org member I know the value. I want to get the redline D4 ATF and change it my self..
I have the FSM.. But I just cant find how much I need to put in after I drain.. FSM says I need X quart(I don't remember) with torgue converter..
It doesn't say whether with flush or drain... can any body suggest me exact Volume..
Old Nov 10, 2002 | 08:38 PM
mtcookson's Avatar
haynes says dry fill - 7 quarts
darin and refill 3.5 quarts, this is on 89-91 but i'm sure it's close
Old Nov 10, 2002 | 09:30 PM
Aaron92SE's Avatar
NWP Engineering.com
Your tranny fluid capacity is 10 quarts. But, when you undo the drain plug on the tranny pan, you will get out about 4.5 quarts. And that's a lot. Just drain it and fill it up with 3 or 3.5 quarts, then check level, then fill accordingly. It's easier than changing your oil. If you have any more questions, just ask.
Old Nov 11, 2002 | 07:17 AM
ATF questions
Just two more questions related to ATF..
1. Is it OK just to drain and refill with Synthetic ATF? Or should I get it flushed by some one else (Midas or else where) then do a refill
2. I have a small leak on the left side of transmission.. It is very minor now. Can switching to synthetic like Redline D4 ATF cause any harm in this condition..? Will leakage get worse after I switch to synthetic..?
Right now I am using a regular ATF..
Old Nov 11, 2002 | 11:56 AM
Aaron92SE's Avatar
NWP Engineering.com
Re: ATF questions
I can't really answer this for you cause I don't know. Hopefully some one will chime in and enlighten us. I've always believed that changing to synthentic on an old car is not a good choice b/c it tends to slips through worn seals much easier and leaks might start to happen. I am using regular ATF right now and I am making sure it's absolutely perfect at all times.
rbuswell
Nov 17, 2016 04:54 AM
foodmanry
Sep 24, 2015 12:02 PM
pjgreek
Sep 9, 2015 09:30 PM
mclasser
Aug 23, 2015 09:32 PM
bill99gxe
Aug 23, 2000 11:28 AM
