anyone like to inhale gas???
Old Nov 17, 2002 | 09:33 AM
shock211's Avatar
need some help here;
whenever i'm letting the car warm up and i turn on the heat/defrost, i'm smelling gas fumes. my fuel filter isn't leaking, and i've never noticed any gas spots on my driveway. why am i smelling gas???
any help is much appreciated.
Old Nov 17, 2002 | 09:41 AM
92vemaxse's Avatar
Well, you wouldn't notice gas spots on your driveway because it evaporates so quickly. Just look under your hood and see if you can find where the smell is coming from. Check your gas lines, injectors, and there should be 2 hoses on the fuel filter, one on top and one on the bottom. Good luck!
Brian
Old Nov 17, 2002 | 05:42 PM
phat's Avatar
check your filler tube. U might have a cut in the rubber hose next to the filler tube.
Old Nov 17, 2002 | 05:48 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
most likely your fuel lines "into" the motor have small hairline cracks in them due to age. during the cold months the lines harden and cracks become more pronounced thus the smell becomes stronger...change the under hood fuel lines and I bet your smell will be gone. if I'm correct the filler tube leak is more obvious, since it will leak as it you fill the tank, thats most likely not your problem though.
Old Nov 17, 2002 | 07:40 PM
Pervis Anathema's Avatar
When you buy the new fuel line, be sure to specify that you need fuel injection hose. Regular fuel line won't cut it. Also, the line size is 5/16 (8mm) Mine was about $5.00 a foot at Auto Zone.
Old Nov 17, 2002 | 08:04 PM
DA-MAX's Avatar
the "Random Lurker" probably told you that...
Old Nov 17, 2002 | 09:01 PM
shock211's Avatar
thnx people
my car is going into the shop next week. i'll be sure to get it checked out.
i'd do it myself but it's too f'in cold and snowy these days.
Old Nov 18, 2002 | 03:25 AM
Yes, he did. What a guy. Apparently, he has been hanging around the other boards. There are some VERY knowledgable people there...
mclasser
22
Nov 12, 2020 01:58 PM
maxinout93
Oct 31, 2015 02:04 AM
ef9
Oct 4, 2015 08:43 AM
