Bad day for the VE.....
Old Nov 22, 2002 | 03:29 PM
MaDMaX024's Avatar
No, its not wrecked. i just found out the extent of its illness. according to alldata, compression should be 184 max, 143 min with less than 14psi variation. well, a few cylinders passed, 170psi and 165psi,dry, the rest were 125-145 dry, and 130-150 wet (compression actually went down on the wet test for the two high cyls)then i decide to test my knock sensor with an ohmmeter. well, between the connector and ECU, i got .554ohm, between the connector and sensor, i got "over limit" meaning there is no connection (or too high for the meter to read but if it made any connection, it shoulda make some noise/blink).
anyway...approximate cost of a rebuild? i can install the heads/accessories/whatever but i dont want to rebuild the heads or measure the block for bearing clearances or whatever (although if someone convinces me that its really not as hard as it seems, i'll do it). i am capable of installing rings/pistons/rods/crank/bearings/seals whatever.
i was thinking about a stroker kit from paeco, custom 260* cams (per nismo87se's advice) and all the porting and polishing i could benefit from w/o sacrificing a nice idle/smooth power delivery.
Old Nov 22, 2002 | 04:34 PM
Jeff92se's Avatar
I'm needing a caw
I know how you feel. My motor seized last week!
Old Nov 22, 2002 | 04:38 PM
92vemaxse's Avatar
Did you post about that?? I don't remember reading about that. Anyways, sux for you! Good luck...maybe another max in the future...
Brian
Old Nov 22, 2002 | 04:39 PM
Jeff92se's Avatar
I'm needing a caw
No didn't post about it. I'm getting another motor.
Brian
Old Nov 22, 2002 | 05:44 PM
James12345's Avatar
Re: Bad day for the VE.....
Paeco stroker kit?
Any info on that?
Old Nov 22, 2002 | 06:45 PM
eric93SE's Avatar
The 1/2 ohm reading you got is okay. But what you need to do is measure between the connector going to the KS(do both terminals in order to have the correct one), and ground (-).
Old Nov 22, 2002 | 08:14 PM
Delvin's Avatar
Ouch...actually, you should feel a bit worse.
Maximajism94se's Avatar
just out of curiosity...how many miles did u and jeff have on your motors when they went bad???
Old Nov 22, 2002 | 09:24 PM
Jeff92se's Avatar
I'm needing a caw
Only 144,000. I suspect I ran it TOOOO low on oil and then ruined a bearing(main/crank)but won't know until I pull the heads etc.
SO VE GUYS, MAKE SURE TO CHECK YOUR OIL LEVELS! In the mornings is a good time or whenever the car has sat for 1 hour or so.
Old Nov 23, 2002 | 09:13 AM
MaDMaX024's Avatar
Re: Re: Bad day for the VE.....
Originally posted by James12345
Paeco stroker kit?
Any info on that?
www.paeco.com
Old Nov 23, 2002 | 09:14 AM
MaDMaX024's Avatar
thats what i meant by my incomplete thought about the whole "over limit" thing in my original post, so i did do that and the meter said theres no connection.
Old Nov 23, 2002 | 09:16 AM
MaDMaX024's Avatar
i have 168k and counting. it still runs well considering its problems. hopefully it'll make it until the beginning of the summer..
Old Nov 23, 2002 | 10:23 AM
James12345's Avatar
Re: Re: Re: Bad day for the VE.....
www.paeco.com
Yeah I was looking at their website last night. I e-mailed them too.
I meant do you have any specifics on it or have you been in contact with them about it?
Old Nov 23, 2002 | 10:43 AM
MaDMaX024's Avatar
Re: Re: Re: Re: Bad day for the VE.....
nope. i was planning something along the lines of VQ bore w/crank to make it 3.2-3.5L....or possibly just destroke to VQ specs since thats where i believe they get their superior torque (bigger bore, shorter stroke).
Old Nov 23, 2002 | 11:41 AM
dmontzsta's Avatar
Ford Only.
Jeff, what are you going to do with that motor?
Old Nov 23, 2002 | 10:31 PM
Jeff92se's Avatar
I'm needing a caw
My upper valvetrain is already accounted for by someone else.
Old Nov 23, 2002 | 10:38 PM
dmontzsta's Avatar
Ford Only.
Upper valvetrain meaning?
How about the Manifold?
Old Nov 26, 2002 | 03:05 PM
Jeff92se's Avatar
I'm needing a caw
Including the manifold
Old Dec 24, 2002 | 01:13 AM
Green Gobblin's Avatar
Hey Mad Max...how much $$$ would that stroker kit be and how much would port and polishing be....I'm trying to find out some other big HP gain for my VE..... I really wanted to make a SC work, but X -mas hit me up hard 2 years in a row....... I f this keep up, "f" Santa I'm gonna have rudolph pull the Max, with a H.I.D kit on his nose.
Old Dec 24, 2002 | 10:47 AM
Nismo87SE's Avatar
Put it this way if you have to ask you can't afford it . Nitrous is a good bang for the buck as for power gains if it's used wisely. BTW it isn't cheating either .
Mar 12, 2020 12:06 AM
Smackasmith
Feb 1, 2016 12:40 AM
97_GXE
Sep 15, 2015 06:47 AM
pjgreek
Sep 9, 2015 09:30 PM
nbstriker10
Sep 4, 2015 04:26 PM
