Dead Cylinder Or Injector Seal Leak
Old Dec 6, 2002 | 03:28 PM
jim.dogleg's Avatar
Somebody took a look at my car 89 GXE 188K miles and indicated they thought I had a bad/dead cylinder.
Somebody else said they thought it might be a injector seal leak. Thinking it could be a seal leak in the the fuel injector seal.
I'm running on 5/6 for now but may actually try get more miles out of it. A compression check should rule out the bad injector problem, correct?
Thanks in advance, wish I had found this when it was warm out.
Old Dec 6, 2002 | 05:59 PM
92vemaxse's Avatar
Try having this person run a compression test. That will tell you if the car has a dead cylinder or not.
Old Dec 6, 2002 | 08:01 PM
eric93SE's Avatar
Re: Dead Cylinder Or Injector Seal Leak
Since you have access to the front injectors you can try unplugging one at a time while the engine is running and if you notice no change in engine idle speed, then that will indicate a bad cylinder.
Chances are it'll be a dead injector, with all those miles one or more will be bad.
Mar 12, 2020 12:06 AM
The Wizard
24
Oct 1, 2015 08:47 PM
RWCreative
Sep 21, 2015 11:01 AM
imported_Nismo_max
Sep 20, 2015 08:19 AM
seesole
Sep 14, 2015 12:38 PM
