Hood Hydraulic Arm Props
Old Dec 6, 2002 | 05:04 PM
CHIMAIRA90
Does your max's hood FALL every time you open it? mine will stay up only when it's below 40 degrees. Are the replacements of the arm props DIY? or should you seek professionals?
Old Dec 6, 2002 | 05:37 PM
AscendantMax's Avatar
Re: Hood Hydraulic Arm Props
mine falls down regardless of temp. it'll hold for a good 2 seconds then BAM! i need to get them replaced soon too...tired of using a ghetto broom stick
Old Dec 6, 2002 | 07:24 PM
doomtoo's Avatar
Re: Re: Hood Hydraulic Arm Props
Yeah, mine does it too, but kind of gradually. It'll stay up for a min or two, depending on the incline, and then, BLAM! If I'm under it, I keep having to raise my back to get it back up again...
Old Dec 6, 2002 | 07:39 PM
kingrye's Avatar
ive been decapitated a couple times
Old Dec 6, 2002 | 08:17 PM
Onemax's Avatar
Yes they are DIY, and it's fairly simple. This has been discussed many times before. I searched for hood struts and found how to and where to get the replacement struts.
Old Dec 6, 2002 | 08:52 PM
Aphrodisiac's Avatar
No mine holds good, out of the billions of time it only fell once... it was scarry.
Old Dec 7, 2002 | 06:30 AM
pest2001's Avatar
mine didnt fall much before but now it falls all the time its up and 2 weeks ago it fell on my hand when i was putting my clear corners on and its still hurting
Old Dec 7, 2002 | 09:00 AM
ShOwMaX
just do what i did an carry a vise grip in your car. Whatever works you know??
Old Dec 7, 2002 | 10:33 AM
Agamemnon's Avatar
So what do you do with the vise grip?
Mine used to fall down unsuspectingly now and then, but now that the weather has turned cold, it won't hold the hood up at all anymore.
Old Dec 7, 2002 | 10:47 AM
mtcookson's Avatar
i use a crow bar, works perfectly when set in the strut mount hole. if you use vise grips you just clamp them on the shiny silver part of the hydraulic pump thing and it will hold it up.
Old Dec 7, 2002 | 02:02 PM
haloboy84's Avatar
Or if you have one wedge your Leatherman Multitool behind the hood strut, that's what i do and it works great. Dont have to worry about needing my Visegrips for something else
Old Dec 7, 2002 | 02:27 PM
89sks's Avatar
The stealer wanted like $200 for them, but I got them at Autozone, they had to special order them, they were like $50 or $75. I cant remember. They arent exactly like oem but work well.
Good luck,
Steve
Old Dec 7, 2002 | 08:32 PM
fattamax's Avatar
Hood Struts
You can get them at Pep Boys
Sach SG325007
Got this info from Chris91se
Good Luck
Old Dec 7, 2002 | 09:14 PM
pezking4's Avatar
I've used a golf club, but I find that a medium sized paint roller expension pole works the best.
Maxima NutBag's Avatar
yeah, mine stay up for a bit, then slowly start to go down.
Old Dec 8, 2002 | 03:08 AM
EdzMax's Avatar
I'm sorry guys, but I have to say this. I live in New Zealand & I would rather spend the money to buy new arms than to use a BROOM STICK. Parts are soo much cheaper up there than down here. I don't mean to **** anybody off, just had to say it.
Old Dec 8, 2002 | 08:36 AM
CHIMAIRA90
wtf? part prices?
gigabyte
Jan 6, 2017 06:05 PM
Pnjboyzz
Nov 16, 2015 12:27 PM
RealityCheck
Oct 2, 2015 06:34 PM
leatherneck
Sep 30, 2015 09:16 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
