Normal RPMs??
Old Dec 10, 2002 | 01:40 PM
maxdout92se's Avatar
Normal RPMs??
Didnt notice this until i put a hole in my tranny pan from an accident, but is it normal to have 2800-3000 rpms at 80 mph....at 60 its a lil (if not exactly on) 2400-2500....even if i have the a/t on comfort mode, still feels like my car is shiftin in power mode!!! any ideals??
Old Dec 10, 2002 | 02:55 PM
Lordrandall's Avatar
It's RPM, not RPM's
Old Dec 12, 2002 | 01:28 PM
Sawby4president's Avatar
Re: Normal RPMs??
That's odd, I had a '92 GXE auto, and at 60 with the torque converter clutch locked it sat dead @ 2000 RPM. 2400 sounds about right for a 5-speed, same with 3000 @ 80. Very odd, maybe your torque converter is damaged and won't lock-up on the highway.
Old Dec 12, 2002 | 05:26 PM
eric93SE's Avatar
Re: Normal RPMs??
Have you replaced your shift selector bushings yet?
Mine did something simmilar, so the tranny is mechanically in Drive, but not electronically. What you can try is while at crusing speed move the shift lever very slightly, try one direction then the other, I know it will only let you slide it into N so for the other direction you will have to depress the shift button while moving the shift lever. If you notice the rpm drop, then its your bushings are bad or gone.
You dont know how much time I wasted adjusting the tranny cable length until I found out about the second bushing.
good luck
Old Dec 12, 2002 | 06:44 PM
thanx for the responses fellas (other than lordrandall's..j/k) i've been meaning to add new shifter bushings..although i don't think thats tha problem...but we'll see...thanks again!!
Miket2006
Mar 1, 2021 03:55 AM
Unclejunebug
Apr 2, 2016 05:42 AM
ef9
Oct 4, 2015 08:43 AM
Need help
23
Oct 2, 2015 08:56 AM
