water pump not so bad w/ help
Old Dec 11, 2002 | 03:17 PM
Maximajism94se's Avatar
well, did the good ole ve water pump...and it actaully wasnt near as bad as i thought...the only other repair ive done, the rear valve cover gasket, was much more time consuming in fact, but w/o using my manual and the write-ups here of cours ei woulda been lost...so heres what i did ...
i basically used my manuals instructions (chilton's) but took the pump out the top. i used the write ups available as help 2...so basically i just took off 2 belts, took off the a/c idle pully, jacked up the engine from the oil pan, and just pulled the bish out...w/o jacking up the engine this becomes basically impossible for me, as i didnt take out the crankshaft pully or nething cause i dont have many tools and such...but neway, just letting those VE owners out there that u shouldnt b scared of doing the water pump...not really that bad
Old Dec 11, 2002 | 04:16 PM
aw89maxSE's Avatar
Re: water pump not so bad w/ help
I am working on replacing my water pump in my 89 max and I swear it is in one of the hardest places to get to and so I am having this other guy help me becuase he has done it before but it is seriously one of the hardest things to get to.
Old Dec 11, 2002 | 04:45 PM
RosenKen's Avatar
That's good, I'll be replacing mine this weekend. Also putting in an ASP UDP since I thought it was required to remove the crank pulley.
Old Dec 11, 2002 | 08:20 PM
nope, no crank pully takin off 4 me...just the tensioner pulleys so i could remove the belts
Old Dec 12, 2002 | 07:08 AM
RosenKen's Avatar
And you jacked up the engine a bit without removing or loosening any motor mounts?
Old Dec 12, 2002 | 10:19 AM
Delvin's Avatar
This makes me feel better about tackling mine. About how long did it take you to do it? I just did a VG water pump at work and it was pretty simple and straightforward. I will most likely be doing mine from the inner wheel well. Who else on here has a write-up on the VE water pump?
Old Dec 12, 2002 | 01:19 PM
Rosenken: hmmm...was i supposed 2 loosen the mounts? ...oh well...
FASHIZL: do i search 4 water pump in this forum...youll find the write up...im jus 2 lazy 2 find it 4 u but if u r 2 lazy as well, just let me know and i can email it...if u don have a chiltons, pick 1 up cause they r god, and not spensive like a fsm or whatever its called...pretty useful advice in those manuals...
captchaos
Mar 15, 2016 12:18 PM
Excalibur23
Oct 13, 2015 04:33 PM
msellas
Sep 23, 2015 09:16 PM
RWCreative
Sep 21, 2015 11:01 AM
brichi
Sep 14, 2015 05:23 PM
