who has an engine block they want to sell me
Old Dec 19, 2002 | 11:30 AM
cosmos's Avatar
Does anyone have an engine block to sell me? I am in Dayton ohio.
94 Nissan Maxima, Sohc. Thanks.
Martin '
dkcao@msn.com
Old Dec 19, 2002 | 01:39 PM
DanNY's Avatar
Ad·min·is·tra·tor
Re: who has an engine block they want to sell me
Martin '
dkcao@msn.com
looking for a bare block?
Old Dec 20, 2002 | 08:40 AM
cosmos's Avatar
Bare block for 94 3.0 sohc and main bearing connector
Yeh am am looking for a bare block with good cylinder walls because mine still runs funny after i honed, ridged reamed, and rebuilt the entire engine. I have not confirmed my findings yet but i am suspecting it. Is it common for these blocks to have piston and cylinder wall wear in the middle cylinders?
Well if you have the engine block in good condition with main conecting bearing mount that would be great and how much? I am researching my possiblities and hopefully do not have to replace the block. Thanks
Martin
dkcao@msn.com
Old Dec 20, 2002 | 10:40 AM
Jeff92se's Avatar
I'm needing a caw
Re: Bare block for 94 3.0 sohc and main bearing connector
Sometimes the tops of the cylinder walls wear more than the bottoms. Did you mic the top and bottom of all the cyliders?
Martin
dkcao@msn.com
Old Dec 20, 2002 | 12:47 PM
cosmos's Avatar
i tried
i tried to measure it but it was descriptive and difficult, but i found out a little more about it today after some testing and tuning that the engine ran better when the timing was adjusted correctly. But when i tried to drive it today the engine light came on and gave me code of 23 and 45. My haynes manual tells me that 45 is a fuel injector leak and i found no leak. Plus the number 23 is not in the manual and i got the same codes before i rebuilt the engine. When the engine light comes on it starts to run shaky and miss a little. But some reason when it goes off it runs fine so i do not think i need an engine block after all (I hope ).
Martin
lowpost99
Oct 26, 2025 06:53 PM
BkGreen97
Apr 2, 2016 05:47 AM
jfl330
Sep 4, 2015 01:44 PM
TheMafia
Sep 4, 2015 08:26 AM
