Timing belt broke. YAY!!!
After hundreds of hours of work rebuilding half my engine my timing belt decided to let lose. It had about 30k on it so I didnt replace it when I had it off originally. Lesson learned. For anyone pulling heads to replace exhaust studs and cams...replace the timing belt while your in there! Now I must pray to god I didnt bend a valve (or 12!).
Re: Timing belt broke. YAY!!!
![laugh](https://maxima.org/forums/images/smilies/laugh.gif)
sorry couldn't resist...good luck.
Re: Re: Timing belt broke. YAY!!!
Originally posted by DanNY
u sure your wood block didn't knock it out?
Re: Re: Re: Timing belt broke. YAY!!!
I knew this was going to happen!!!! I think Im going to try my block of wood method on the whole damn car this weekend. Wish me luck.
se-r.net soon enough.
Re: Re: Re: Re: Timing belt broke. YAY!!!
Honestly. One of two things: 1) If my prayers have been answered then I dont have any bent valves and when I replace the belt all will be well 2) valves are bent and its time for a new car. I just tore that engine down to the block two weeks ago and I really dont want to do it again. Id hate to leave the lovely climate of Maxima.org (wood...blocks...ahhhhhhh!) but I may be relocating to
![Slap](https://maxima.org/forums/images/smilies/slap.gif)
well it's not a total loss..if the car overall is in good shape..if it is then get a set of heads and slap it in..(given the bottom end is ok)..if not then get a boneyard motor...and REPLACE THE T-BELT.
Re: Re: Re: Re: Re: Timing belt broke. YAY!!!
well that's a bad move on your part man. you had it all torn down and everything but u reused the t-belt...ouch![Slap](https://maxima.org/forums/images/smilies/slap.gif)
Re: Re: Re: Re: Re: Re: Timing belt broke. YAY!!!
I think I may have had the T-belt tensioned improperly actually. Theres a spec. for the tension but I didnt have the tools to set it. Takes some wierd micrometer set-up. I could fix it but I live in Hawaii and finding parts for this car is really expensive. I think I may have to cut my losses and move on. Its sad because I just dropped about 6k on this car too. Its in perfect shape since I had a real paint job done 3 weeks ago. Its back to its showroom emerald green, ALL dents removed. We'll see, I love my car but I work hard for my money and I just might be smarter to spend it on a new car. BTW, glad we've moved past our blocks of wood phase Dan.
![Big Grin](https://maxima.org/forums/images/smilies/biggrin.gif)
Originally posted by Nismomaxt I think I may have to cut my losses and move on. Its sad because I just dropped about 6k on this car too. Its in perfect shape since I had a real paint job done 3 weeks ago. Its back to its showroom emerald green, ALL dents removed. We'll see, I love my car but I work hard for my money and I just might be smarter to spend it on a new car. BTW, glad we've moved past our blocks of wood phase Dan.
![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
Re: Re: Re: Re: Re: Re: Re: Timing belt broke. YAY!!!
Originally posted by CandiMan
For this reason alone if it was "me" I wouldn't cut my loses. Mistakes happen, some cost more than others. I don't know how much valves cost, maybe $100 in gaskets and your good to go, it's not like you have to tear apart the short block. And with the body just getting "a real paint job" the car sounds like it was worked on pretty good in and out. If you are considering getting rid of the car as is, keep in mind most will take a mechanically sound car (eng/susp) over a prestine body unless they're aware of what it would take to repair the motor/susp. Depending on your time/money I say pull the heads, replace the valves and enjoy your motor for another 150k+ then again the SE-R.net is a nice replacement with more after-market support
Re: Re: Re: Re: Re: Re: Re: Re: Timing belt broke. YAY!!!
well good luck I just bought a car from a friend that let the t belt break. It had every valve bent in it. I would guess that you have at least 1 but probably all bent. I spent about 400-500 at the machine shop but that included the gaskets, all 12 new valves, new intake guides. You have already put a lot of money in the car...I would fix it and sell it because you will not get much for a car with a bad motor.
Good luck
Good luck
tsi6001
10-03-2022 10:23 PM
Ray229Harris
09-16-2015 08:16 PM
Maxima2010 Prem
08-13-2015 11:34 AM
