Motor Mounts bad, or something worse?
Old Dec 25, 2002 | 06:20 PM
Spipedong90's Avatar
You may have read my other thread about how I took my newer SE in for a wheel balance because I had this bad vibration while accelerating between 40 and 55. They replaced my drivers side wheel bearings and cup and balanced all 4 wheels. The problem is still there. It's almost like passenger front wheel is out of round but it only occurs at those speeds. It also goes away if I coast at the same speeds.
I jacked the whole front end up last night to try to get an idea of the problem. When I let out the clutch I heard this sound; it's hard to describe, almost like maybe an arrow stapler or something, sort of like metal hitting a really dense piece of metal. The noise occured every time the wheels went around, and at the exact same time as the sound, the engine would drop a couple inches on the passenger side. WTF is going on?! I had someone ease the clutch out while I looked under there but I couldn't find anything that would cause the sound/engine shifting. Does this sound like a bent shaft, broken mounts, bad CV joint, or just a fluke because I had the car jacked up and the wheels hanging down? Also, I don't hear the sound with the wheels on the ground, but I guess that doesn't mean it's not still shifing the engine up and down.
I plan to take the car back to the place that did the work and harass them about it because I took it to get the vibration fixed and they didn't do it. Granted they fixed something else that was a huge problem, but my problem wasn't fixed. This isn't even something they could have overlooked while test driving it since the whole car bounces up and down nauseatingly.
Old Dec 26, 2002 | 08:52 AM
Matt93SE's Avatar
STFU n00b!
sounds like a bent axle to me.
Old Dec 26, 2002 | 10:25 AM
Wouldn't a bent axle be felt at all speeds?
Not trying to disprove your theory...
matts95max
Apr 23, 2025 10:44 AM
wyobbagy
Jan 3, 2023 12:03 PM
The Frye
Sep 2, 2021 11:03 AM
AcuraLegend
Oct 17, 2016 08:47 PM
