90 GXE: Digital Dash issues...
Old Dec 26, 2002 | 01:12 AM
SWEETSOUND2001's Avatar
I have a 90 GXE. The car came with a digital dash. When I bought the car, the dash did not work so I ended up buying another unit from one of .org members. Now it works great which brings me to the next question. I swapped the brains using the same cluster and it appears that the Brain/control unit for my dash is broken. I used both LCD displays with that brain and neither one worked and they both work with the good brain. I found one of the posts that it is usually some resistor or burnt leads on the unit that leads to the failure. I have the brain out of the car and can take a picture if necessary. Do any of you guys have experience with fixing these type of parts and if so maybe you can be of some assistance. Also, my AC Climate Control LCD display is very dim and I think it may be a similar problem. Any ideas? Also, on my new unit, the odometer shows 123k kilometers and only 2300 miles of use. It came out of a Canadian car. How is this possible? I'd like to use my old brain so it will show the original mileage.
Here's another thread about this:
http://forums.maxima.org/showthread....igital+cluster
Anton
Sweetsound2001@maxima.org
Old Dec 27, 2002 | 04:33 PM
run2thesun's Avatar
Re: 90 GXE: Digital Dash issues...
Anton
Wow thats weird. I have a 90 GXE and the climate control display is very dim. My car says 123 MILES but only 3000 KMS on the odometer! And I live in Canada!! Hmmm ever heard of car cloning
Old Dec 28, 2002 | 03:27 PM
ninezero's Avatar
I fixt my dash by renewing a small electro part.
Its a small black part with the code ZNR k 220 03 on it ,this is
somekind of a safety electronical fuse.
Try to find out if it is burned inside just by a little scratcing
with a small screwdriver or something.
Old Dec 28, 2002 | 11:11 PM
90inthemaking's Avatar
Re: Re: 90 GXE: Digital Dash issues...
What was specifically wrong with your dash?
Old Dec 29, 2002 | 07:07 PM
ninezero's Avatar
Re: Re: Re: 90 GXE: Digital Dash issues...
It did not work at all
Old Dec 29, 2002 | 07:10 PM
Re: Re: Re: Re: 90 GXE: Digital Dash issues...
Where was the part located? Is it inside the gauge cluster ECU or elsewhere?
Old Dec 29, 2002 | 09:18 PM
I just took a couple pictures of the brain. I circled the areas that have some yellow liquid on the circuit board in red. What does that mean?
http://myweb.thump.net/629819/pc281533.jpg
http://myweb.thump.net/629819/pc281535.jpg
Old Dec 30, 2002 | 11:19 AM
So, after you messed with the electrical part it started functioning again?
Old Jan 1, 2003 | 12:56 PM
ninezero's Avatar
Re: Re: Re: Re: Re: 90 GXE: Digital Dash issues...
The digital dash has two parts ,the LCD part and the electronical
brain ,they are mounted with screws together .
You have to separate this two parts.
The znr is located soldered )on the electronical print.
Old Jan 1, 2003 | 01:00 PM
ninezero's Avatar
Yes and this happened about two years ago and the dash is still
working 100 %
Old Jan 2, 2003 | 09:06 AM
max4me's Avatar
Hey Anton
I'm pretty sure the yellow liquid is flux which is use to solder. Looks like someone tried to replace this chip either to fix the module or to disguise the mileage on the vehicle. I'm an electronics tech and from experience the success rate of removing and reinstalling that type of chip is very low. In a lot of cases you will get either bad joints between the board and the leads or solder wicking which will short two or more of the leads together. I sent you an e-mail explaining the 123Km - 2K Miles question. Did you receive it?
Old Jan 2, 2003 | 10:06 AM
Originally posted by max4me
Hey Anton
So what you're saying is short of me sending my ECU in to the company that fixes them for $300, I'm going to have to sell the car as true mileage unknown? I didn't get your email.
Old Jan 2, 2003 | 05:40 PM
max4me's Avatar
That chip was on the instrument cluster, wasn't it???
Part of e-mail:
For some reason that I could never figure out (must be something to do with the memory or maybe the Japanese just can’t count over 200,000(just kidding)) the digital odometer rolled over at 200,000. The cluster has 323,000 km or 323,000 x .625 = around 202,000miles.
Run2thesun's post: Wow thats weird. My car says 123 MILES but only 3000 KMS on the odometer! And I live in Canada!! Hmmm ever heard of car cloning ....
makes sense to...his car has 123,*** miles or 123,*** x 1.625 = 203000km ...rolled at 200000 so only shows 3000.
worldwiderecognized
Sep 30, 2015 01:16 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
