polishing question, have searched
Old Dec 31, 2002 | 10:09 AM
rustangkilla
I've been searching a lot for this question and have not found an answer. On the picture I have included here, what is the best way to go about polishing what I have circled? Also, what metal is it?
any help is much appreciated!
Old Dec 31, 2002 | 01:39 PM
rustangkilla
Re: polishing question, have searched
::bumpsy:: C'mon guys, I want to start this job...
Old Dec 31, 2002 | 01:46 PM
Michael's Avatar
Back in a 3rd Gen.
Re: Re: polishing question, have searched
If you really want to do it yourself and have an air die grinder then check out summit racing, Jegs, or jc whitney for a intake polishing kit. They are like 20-30 (or used to be) and has everything you need to do it.
If you do not have an air die grinder it will be a lot more difficult.
Old Dec 31, 2002 | 01:47 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
I found this in the search, read this link, maybe Sudesh can help
http://forums.maxima.org/showthread....ghlight=polish
Old Dec 31, 2002 | 03:13 PM
Sudesh's Avatar
yeap..right now i'm awaiting a few more tools before I can open up www.hipershine.com for business.
Anyway...i'll offer some tips for how you can do it at home yourself with pretty okay results.
You would have to sand the roughness out of it first, using a rotary tool with the sanding bits you can get off the rough surface. Then you can use some polishing compounds (available at home depot)..Use a polishing wheel to rub the compound onto the metal till it shines thats pretty much it for a DIY job.
Mar 12, 2020 12:06 AM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
pears
Sep 18, 2015 05:25 AM
