Craig: Question regarding wiring (Similar to the warning chime thing)
In the thread here: http://forums.maxima.org/showthread....light=ignition
another guy brought up an interesting problem that I am experiencing as well. I removed my lock timer because I could never lock the doors, or they'd lock on their own. I'm pretty sure it's related to the fact that my ignition switch is totally shot, but if I don't have to replace it, I don't want to (I like the added freedom it gives me)
However, I miss my power locks... I have snipped the wire that activates the warning chime, but is that the same wire the timer uses to determine whether it should lock the doors or not?
In other words, I know there is a built-in security feature that doesn't lock the drivers side door if the key is in the ignition. Is the wire that controls that the same as for the warning chime? If not, which one is?
I want to see if I can just cut the wire and have the locks work correctly again.
If there isn't a wire, then I guess I'll buckle down and by myself a new switch (Yay, $120 more gone)
Thanks in advance!
Thanks in advance!
Re: Craig: Question regarding wiring (Similar to the warning chime thing)
Thanks in advance!
Thanks in advance!
the wire you cut for the key-in chime is at the time control unit (not door lock timer). The time control unit doesn't control the locking or unlocking at all.
I'm not sure about a feature to prevent the drivers door from locking, mine seems to lock fine if the key is in or not.
I think you should probably go ahead and get that igntion replaced
good luck and hope that fixes your problems
melteye
May 16, 2016 12:02 AM
sake1bs
Sep 19, 2015 09:32 PM
JMag90
Aug 25, 2015 09:17 AM
doobadoo
Aug 15, 2015 06:43 PM
