Found my gas leak
Old Jan 3, 2003 | 10:06 AM
probmxstyle's Avatar
Found my gas leak
I finally found my gas leak. I believe its called the return line or the top off line. it has a crack in it. I hope to get under there soon to fix it.
Old Jan 3, 2003 | 10:20 AM
crazy4maxima's Avatar
Re: Found my gas leak
do a search for "fuel filler recall".. you can get it fixed at dealers expense.. if it is caused by salt and mud... eating away the tanks .... call nissan companyh and have them look at your maxima...
Old Jan 3, 2003 | 11:36 AM
I dont see how salt and corrode the rubber hose. I am not talking about the metal pipe that the gase goes into the tank in.
Old Jan 3, 2003 | 11:41 AM
DaBoxSE's Avatar
which year 3rd gens was this recall for? I went to my nissan dealership and they told me that my car was not covered under the recall when they checked my VIN#. I have the same gas leak in my return line as probmxstyle and I was hoping to get it fixed by the recall.
Old Jan 3, 2003 | 07:49 PM
Hey daboxse i have the same year and model as you. I havent taken mine to the dealer but when i do i will let you know if they tell me the same thing.
Old Jan 3, 2003 | 10:12 PM
eric93SE's Avatar
The recall only covered the filler neck region. Crap building up between the pipe and the platic cover leading to a failure in the pipe.
Which region of the return line are you guys talking about???
Old Jan 4, 2003 | 08:37 AM
«§»Craig B«§»'s Avatar
I'm not sure the year, but it has to do with the region the car is from. I dont know which states it applies to, but I think it's mostly NE cars; maybe that's why you got rejected
Old Jan 4, 2003 | 09:36 AM
DanNY's Avatar
Ad·min·is·tra·tor
Re: Re: Found my gas leak
Old Jan 4, 2003 | 05:22 PM
There is a smaller hose above the pipe that the gas goes into the tank in. its about a inch in diameter.
Old Jan 4, 2003 | 06:42 PM
yeah that is what i meant about the filler problem.. not the tank but the filler tubes...http://forums.maxima.org/showthread....hreadid=106401
http://forums.maxima.org/showthread....all+filler+gas
http://forums.maxima.org/showthread....ght=gas+recall
check for recall here on the nhtsa website..
NHTSA CAMPAIGN ID Number: 95V244000
Component: FUEL:FUEL TANK ASSEMBLY:PIPE:FILLER:NECK
Manufacturer: NISSAN NORTH AMERICA, INC.
Make: NISSAN
Model: MAXIMA
Recall Date: 01/02/1996
Potential Number of Units Affected: 747000
Manufactured: 08/1988 - 02/1994
Defect Summary:
IT IS POSSIBLE FOR A MIXTURE OF MUD AND SALT TO GET TRAPPED BETWEEN THE FUEL FILLER TUBE AND WHEEL HOUSING. THE TRAPPED MUD AND SALT CAN RESULT IN CORROSION OF THE FUEL FILLER TUBE AND THE WHEEL HOUSING.
Consequence Summary:
SIGNIFICANT CORROSION OF THE FUEL FILLER TUBE MAY RESULT IN FUEL LEAKS WHICH IN THE PRESENCE OF AN IGNITION SOURCE COULD RESULT IN A FIRE. IN ADDITION, THE LEFT REAR SEAT BELT RETRACTOR IS MOUNTED TO THE WHEEL HOUSING AND IN THE EVENT OF SIGNIFICANT CORROSION, AND THE MOUNTING COULD FAIL IN A VEHICLE CRASH.
Corrective Summary:
DEALERS WILL INSPECT THESE VEHICLES AND CORRECTIVE ACTION WILL BE TAKEN DEPENDING UPON THE EXTENT OF THE CORROSION.
here is the info.. now talk to nissan..but heck i guess this is better information that what i stated before.. sorry for the mix up folks...
Old Jan 6, 2003 | 10:17 AM
DaBoxSE's Avatar
In tha case, I think that my car was originally from Texas, but it has been in MA since 1994 so that means im stuck with any problems I may have. That stinks.
Old Jan 6, 2003 | 10:36 AM
Old Jan 7, 2003 | 09:27 AM
male's Avatar
I had the same leak..glad it wasn't the fuel filler tube. I think that is a vent line. Easy fix, just a little tough to get to.
Mar 12, 2020 12:06 AM
captchaos
Mar 15, 2016 12:18 PM
ag90fox
Sep 9, 2015 12:22 PM
Hdnseek
Sep 9, 2015 05:55 AM
dcam0326
Sep 7, 2015 07:26 AM
