engine degreaser
Old Jan 9, 2003 | 02:29 PM
AscendantMax's Avatar
engine degreaser
Spent a good part of today cleaning my max. now i'm in the process of cleaning out my engine bay. i got most of the dirt and crud off just with some soapy water and a good shop rag. now there's still some hard junk to get off in certain places in the bay. was wondering what brand of degreasers you guys use. any recomendations? (spell check) and tips? thanks in advance
~fosgate fan
Old Jan 9, 2003 | 02:33 PM
Jeff92se's Avatar
I'm needing a caw
I just usually go down to the car wash and use their degreaser. Just be careful not to use the high pressure and try not to spray directly onto the electrical connectors. If you are VG, careful with the dist and coil
Old Jan 9, 2003 | 02:42 PM
5spd92SE's Avatar
Yeah what Jeff said. Its preferable that you find a carwash that has a hot rinse. This will help the water evaporate faster.
I also use the carwash degreaser and leave the engine running.
It works great.
Old Jan 9, 2003 | 02:47 PM
yea my max is a VG and was worried about spraying the engine with the car wash's pressure washer, afraid that it'll die on me. That's why i used some old fashion elbow grease . But i guess i can try and do what u guys said at the car wash. and yes they have hot rinse But is it ok for the elctrical system to get a little wet?
Old Jan 9, 2003 | 03:00 PM
Jeff92se's Avatar
I'm needing a caw
Well the hose will have good pressure w/o pulling the trigger. If you pull the trigger the water BLASTS out! The normal pressure is plenty.
I don't wash the engine w/ it running. The electrical system has connectors to protect it from the elements but it was never meant to handle ALOT of direct water pressure so be careful
Old Jan 9, 2003 | 03:22 PM
Soul Fly
DON'T USE PURPLE POWER!! Eats thru paint
Old Jan 9, 2003 | 03:34 PM
Gjohnson's Avatar
Jeff92se,
So all you do is spray the degreaser on the engine, without pulling the triger. Do you rinse it off, or just let it sit? I've been looking for a good way to clean my engine bay too, but don't want to short circuit anything. Thanks for any tips...
Old Jan 9, 2003 | 06:03 PM
Michael's Avatar
Back in a 3rd Gen.
the best stuff I have used it Greased Lightning. That stuff works great.
Old Jan 9, 2003 | 07:19 PM
NismoWeEatHonda's Avatar
I Degrease my engine once every 2-3 months and what i do is go down to those car was places spray degreaser in the desired place and then as a percation i cover electrical parts with plastic bags (like from the grocery store) and then i spray it off but i do not do this while it is running, after i have sprayed i take off bags and turn engine on right away and let it run for like 5 min i have been doing this for a while now and no problems at all oh and by the way its a vg
Old Jan 9, 2003 | 09:41 PM
ghettogeek's Avatar
:-O
I used purple power...now it's everything under my hood is spotted white!
Old Jan 10, 2003 | 07:02 AM
davecmu's Avatar
Simple Green
Good for the car, good for the environment. Smells greeny fresh!
Old Jan 10, 2003 | 08:30 AM
SnickterP's Avatar
Greased Lightning, or Gunk. Thats all you need.
Old Jan 10, 2003 | 09:50 AM
Nismomaxt's Avatar
Re: engine degreaser
~fosgate fan
Castrol super clean works awesome but I strongly suggest masking off any painted areas you care about. Its real foamy so any breeze will blow it onto the sides of your engine bay or onto a nearby car so be careful. Of course you could just use simple green and not worry about this but it will take a little more effort.
Old Jan 10, 2003 | 02:21 PM
thanks for all the tips guys! my engine is now clean....well cleanER then before the junk was removed. thanks again
Old Jan 10, 2003 | 02:27 PM
karguy's Avatar
Re: Simple Green
Also recommend Simple Green. It is environmentally friendly and biodegradable. I do it at home and wash suds and dirt into grass since it doesn't hurt anything. I spray it on warm non running engine, let it sit for about 10 minutes and hose it off using high pressure low flow spray. Start car ang go for short ride to dry engine bay off. No white spots and it has a very pleasant fragrance. I have done it 4 times so far w/o any problems. Best price for it is at Walmart!
James92SE
142
Jan 2, 2024 09:23 AM
homewrecker
Sep 24, 2015 07:01 PM
msellas
Sep 23, 2015 09:16 PM
Socalstillen
Sep 20, 2015 11:46 PM
seesole
Sep 14, 2015 12:38 PM
