VE stalling and stuttering
Old Jan 13, 2003 | 11:38 PM
Maximan190's Avatar
every now and then in the past week or so, the car would stall at idle when parked..
tonight it really hit; after sitting for a few hours i start up then stalls... start up again then stalls 2 minutes later. So i drive home and it keeps stuttering as i accelerate. As i stop for red lights it would stall or the rpms would flutter between 500 and 800 like it was about to die out
what i think it may be are clogged fuel injectors.. sat 11th i was on my way to work, already late when my fuel light just came on, so i figured id gas up after work.. of course i hit major traffic caused by people stopping to look at an overturned truck on the other side so it obviously used up more gas and JUST as i pull into the parking lot, car shuts down as i coast into a spot
i did a quick search and found the injectors to be the problem for some people, i just want some more thoughts..i use chevron fuel cleaner after every oil change, 3k miles
wierd thing is, it stalled once before this ran-out-of-gas problem, but tonight it was bad
Old Jan 14, 2003 | 06:52 AM
MaDMaX024's Avatar
Re: VE stalling and stuttering
fuel pump? filter? gremlins?
Old Jan 14, 2003 | 06:59 AM
blackonblack
Is your MAFS. Do a search on stalling & MAFS you will find your answer
Old Jan 14, 2003 | 07:46 AM
D-sta's Avatar
using fuel cleaner can sometimes be bad because the chemcals are too harsh and might eat up the fuel injectors themselves. I would also suspect it's a bad fuel injector.
Old Jan 14, 2003 | 07:53 AM
Derek94SE
It's not always the MAFS, it can also be the injectors, O2 sensor, and the wiring harness for the MAFS. I'm sure there are other causes as well, those are the ones I remember off the top of my head.
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
97_GXE
Sep 15, 2015 06:47 AM
Rage Maximus
Sep 3, 2015 12:26 PM
