Now im having battery problems
Old Jan 17, 2003 | 06:06 PM
BurgandyMAX's Avatar
I have a new battery and my altenator is not going. But i have to charge my battery every night so my car does not die on me. It seems if i leave it sitting for a white something drains it. I have checked almost everything. I am lost!!!! Please Help!!!!!
Old Jan 17, 2003 | 07:19 PM
lophix's Avatar
Re: Now im having battery problems
have you tried a different battery? does sound like a drain but you never know...
Old Jan 17, 2003 | 08:15 PM
Re: Re: Now im having battery problems
Yea changed battaries Twice!
Old Jan 17, 2003 | 08:27 PM
MaximaBalla's Avatar
Try tightening down your connections, I kinda had the same problems only my stuff would flicker on and off? And it kept restarting everything!! Hope this helps!!
Old Jan 17, 2003 | 08:40 PM
Yea i tried that too, the problem started when i tried to hook up some lights to my cornering lights, but i ended up not hooking them up, now my battery just drains itself. If it isnt driven everyday or started every other day for about 4 months could this be a cause?
Old Jan 18, 2003 | 08:16 AM
karguy's Avatar
Sounds like you have a high resistance short. Check out the wires you were working with when you were trying to hook up the other lights. I would also have my alternator checked, a short or a partial short in the Diode(s) will also cause the problem you described. Most car parts stores will do this for free! Hope this helps.
Old Jan 18, 2003 | 03:19 PM
phat's Avatar
battery
What is your voltage reading when the engine is on. You might have a bad alternator. If the battery is good, the alternator should charge up your battery. If the alternator is bad, the battery is not getting recharged.
Old Jan 18, 2003 | 04:10 PM
lophix's Avatar
yeah i think it must be the wires you were working with too....probably a bare wire touching something else or wired wrong. pull out all the wires you were working with and observe...
DJLAX152
May 4, 2021 11:46 AM
JoshG
51
Sep 21, 2015 10:41 PM
markevans999
Sep 10, 2015 04:29 PM
