Clutch fluid leaking.
Old Jan 20, 2003 | 08:11 AM
nstymax93's Avatar
I think my clutch fluid is leaking but where would i begin to look for that leak at?
Old Jan 20, 2003 | 08:16 AM
Jeff92se's Avatar
I'm needing a caw
I told you where to look in the other thread.
Old Jan 20, 2003 | 03:07 PM
«§»Craig B«§»'s Avatar
just follow the lines
start at the clutch master cylinder, then it goes down and across the top of the tranny to the clutch slave cylinder which is right above the starter and pushes on the shift fork
if you cant find anything there, look up high at the base of the clutch pedal and see if it's leaking inside the cabin
it's a pretty simple hydraulic system so it shouldn't be too hard to track down
Old Feb 10, 2003 | 11:32 AM
Aqno's Avatar
I've been having this same problem. It appears the leak IS inside the cabin at the base of the clutch pedal! What do I do next? Sorry for asking if its already been answered, but I couldn't find anything else when searching the forum! Thanks!
Old Feb 10, 2003 | 11:44 AM
Jeff92se's Avatar
I'm needing a caw
What is it leaking from? The only thing up there is the clutch master cylinder. So the logical conclusion is to replace the clutch master cylinder. How do I do that? Look for my post about repair info in the permanent posts on the top of this section.
user 11122324
42
Jul 18, 2022 03:35 PM
Mar 12, 2020 12:06 AM
Need help
23
Oct 2, 2015 08:56 AM
carlosvq30
Sep 26, 2015 09:44 AM
