solenoid pack part number
Old Jan 21, 2003 | 07:04 PM
rfogle's Avatar
Anyone know the part number for the solenoid pack located by the driverside strut tower on a '90 SE auto? I believe it's one of the packs that controls tranny line poressure.
Old Jan 22, 2003 | 09:07 AM
eric93SE's Avatar
Re: solenoid pack part number
I think your talking about the 'dropping resistor'. Is your max shifting really hard? If not, then there is something else wrong.
The solenoid pack for the tranny is not visible (inside the tranny).
Old Jan 22, 2003 | 02:20 PM
rfogle's Avatar
Re: Re: solenoid pack part number
My problem was that the tranny was slipping in every gear. I lost overdrive also. I read somewhere in a search that there is a black canister next to the driver side strut tower that everyone was calling a solenoid pack. It was written that if you unplug this canister and your tranny problems went away than that was the problem. I unplugged it and my tranny shifts fine other than a little too hard so i guess that was my problem. Now I'm trying to find the part number for this piece so that i can replace it.
Old Jan 22, 2003 | 02:55 PM
Gjohnson's Avatar
Is this for the VE, because mine is shifting hard 1st gear.
Old Jan 22, 2003 | 03:09 PM
rfogle's Avatar
Yes
Old Jan 22, 2003 | 05:06 PM
eric93SE's Avatar
Yes
Dude you dont have a VE they were only made in 92-94se's
You have a VG, VERY DIFFERENT, different engine and tranny.
If you think it the dropping resistor, then its easy to replace.
Old Jan 22, 2003 | 05:09 PM
rfogle's Avatar
You're right. VG.
Old Jan 24, 2003 | 08:31 AM
Rodrv6's Avatar
The solenoid pack is located inside the transmission under the valve body. The connector you unplugged is for the dropping resistor that controls the current to the line pressure solenoid (part of the pack). The dropping resistor is probably OK and the pack in the tranny is what you need to look at. The black can that the plug is mounted on is a vacuum tank for the intake "power valve" and has nothing to do with the tranny.
MR2 T'd
Jul 9, 2021 05:06 AM
dvcamp
Sep 18, 2015 10:17 AM
dcam0326
Sep 8, 2015 11:02 PM
mikebla
Sep 3, 2015 05:37 PM
crazyespn
Sep 3, 2015 01:30 PM
