injector puller
Old Jan 24, 2003 | 11:36 AM
mo90gxe's Avatar
injector puller
anybody know where i can find an injector puller..if there is such a thing...???
Old Jan 24, 2003 | 12:57 PM
91nissan03's Avatar
I don't know if there's a official puller, I wrapped a rag around it and yanked it out with some pliers. It didn't damage anything and the new one hasn't leaked so far.
Old Jan 24, 2003 | 05:13 PM
eric93SE's Avatar
Mine wouldnt budge (and I have 19.5 inch arms) yanking on them with vice grips. What I did was use a bench vise with the sharp gripping plates (not the smooth surface ones) but I only tightened the vise gently, then rotated the fuel rail back and forth while pulling. It was a snap after figuring that out.
Old Jan 24, 2003 | 08:46 PM
crcorc's Avatar
Re: injector puller
I recently did this: Spray some WD-40 down between the injector and the rail to loosen them up a bit, then gently place the plastic connector end in a bench vice. Holding on to the fuel rail (the pintles are facing you) rotate back and forth while gently pulling on the rail. Note the use of the word gently. They should pull out easy.
Good luck.
Maxboy23
55
May 1, 2025 06:09 PM
James92SE
142
Jan 2, 2024 09:23 AM
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
