did vtc grounding while motor was flushed
Old Jan 30, 2003 | 12:06 PM
Maximajism94se's Avatar
well, it was oil change time so per eric's advice i did the vtc grounding and hooked up a switch to it, so while i ran my flush i grounded and ungrounded the vtc assembly...
u could actually here the grounding take place, it was a short "snap" when grounding occurred, also the sound of the idle would change slightly after a second or two, not immediatly
i have perfectly functioning vtc assemblies, and hopefully this will keep the oil gallies clean, ill post ne new developments, e.i. if the car sounds quieter, motor blows up, ect as they happen
Old Jan 30, 2003 | 01:52 PM
eric93SE's Avatar
Re: did vtc grounding while motor was flushed
Good job, Now your motor should be ready for a 200 SHOT
Old Jan 30, 2003 | 03:34 PM
ummmm....maybe later lol
i am goin 2 the track prolly tomorrow, ill let u guys know how i do, plus ima run 1 time w/ vtcs on the whole time...see how much it takes away...good job
Old Jan 30, 2003 | 04:03 PM
eric93SE's Avatar
Personally I would'nt do that, I'm not totally convinced its good for the ECU when done for long periods like many have done. We already know you'll loose a lot when they are grounded.
Have fun at the track, and if you can play with advancing the timming to see the advantages in it, as long as you know what you are doing.
Old Jan 31, 2003 | 09:22 PM
well, the car was running so well i didnt mess w/ nething really...times were (in order) 15.907@87.78,15.673@88.33, 15.882@87.75, and 15.879@87.72
i was very surprised the car ran so strong...only mod in a drop in k&n and its kinda borderline to even call that a mod...of course since im painting the car its short over 100lbs after i took out the spare, jack, the rear door covers, door insulation, spoiler, and lotsa paint (good 4 a couple lbs right lol)...even so, im very very happy w/ my car right now (auto btw)
Old Feb 1, 2003 | 06:10 AM
CandiMan's Avatar
Say Candyman 5 times
Originally posted by Maximajism94se i have perfectly functioning vtc assemblies, and hopefully this will keep the oil gallies clean
Unfortunately you do not have perfectly functioning VTC's, and the grounding will not help keep the gallies clean. Grounding the VTC's you are keeping the VTC engage (or disengage, I cant remember) at all times, so instead of being controled by the ECU you are controlling them. Regurlar PM service and good quality oil is only way to keep your gallies clean. FYI, it has been known for VTC's to start clicking (after a period of time) even after being grounded. Cheers
Old Feb 1, 2003 | 03:32 PM
Re: Re: did vtc grounding while motor was flushed
well bish...i do use mobil 1 oil and filter, what is PM service? im guessing its something really obvious and that by asking what it is i will look stupid, but thats my risk...lol
Old Feb 2, 2003 | 07:26 AM
eric93SE's Avatar
Mike, he installed a switch to temporarilly ground his VTCs while doing a motor flush. He doesnt have anything wrong with his vtc (not ticking) he just did this as a maintanance measure.
Maximajism94se, those are some damn good times for a stock VE
Old Feb 2, 2003 | 11:20 AM
CandiMan's Avatar
Re: Re: Re: did vtc grounding while motor was flushed
PM = Preventive Maintenance
(i.e. fluid change, tire rotation, suspension work, tune-up, etc.)
You said, it made you may look stupid
bish...
Old Feb 2, 2003 | 01:50 PM
thanx...i just wish i could pull some times like ben (4th gen) 15.1 w/ an intake...geez!
yes...i think lol
Old Feb 27, 2003 | 02:33 PM
cneary812's Avatar
Re: Re: Re: Re: did vtc grounding while motor was flushed
Even with good PM the VTC's can go bad. That was the flaw in our engine. Hense the fact that it only lasted 3 years!
user 11122324
42
Jul 18, 2022 03:35 PM
AaronL
Aug 8, 2020 10:31 AM
D Mason
Jun 21, 2016 04:43 AM
Unclejunebug
Apr 2, 2016 05:42 AM
