Audio Install
Old Feb 12, 2003 | 04:34 PM
Gjohnson's Avatar
Audio Install
I started to install an Amp and 2 12's today on my lunch break and thought I would have to burn the car. OK, whats the deal with getting the back seats out. Out of all the cars I've owned I've never had that much trouble pulling the back seat. Anywayz, what I need help with is, running my power wire. For those of you that have installed a system on their Max, does anyone know the easyiest way though the fire wall. I don't want to drill or anything like that, so I'm looking for some existing cables to follow. Thanks
Old Feb 12, 2003 | 04:38 PM
«§»Craig B«§»'s Avatar
search for "firewall" or something like that. There are many threads about this.
Most people run it through the drivers side wheel well...
Old Feb 12, 2003 | 04:41 PM
probmxstyle's Avatar
No existing holes big enough to fit 4 guage wire through. Just drill a whole on the driver side of the fire wall. Its easy and cleaner.
Old Feb 12, 2003 | 10:04 PM
Matt93SE's Avatar
STFU n00b!
yes there are. in my GXE, I ran a 2 awg wire through the hold for the hood release cable.
on my SE, the wire was even bigger, so I just drilled a hole in the firewall and stuck a grommet in there. easy cheezy.
www.ee.utulsa.edu/~mblehm/pics/car/stereo/wiring
Old Feb 12, 2003 | 11:54 PM
EdzMax's Avatar
Well, I just install a alpine amp last week & I found a rubber groument already in my fire wall. Took that one out, made a hole big enough for the wire. Sweet ***. I guess my Max is different since I'm right hand drive. Found it on the passenger side. Had heaps of space.
Old Feb 13, 2003 | 09:22 AM
Redmax's Avatar
Redlinemax Owner
Re: Audio Install
Yes, there is no open grommet for the 4 guag to go through. Gotta drill a hole !
Old Feb 13, 2003 | 09:35 AM
Michael's Avatar
Back in a 3rd Gen.
Re: Re: Audio Install
Yes there is...look up to what Matt just posted. I did the same thing he did without a problem.
where the hood cable comes from is plenty big enough for a 4 ga I put a 4 ga. there and Matt used a 2 ga. there. but if you want to drill a hole thats fine too just be sure to use a grommet so it will not mess the wire up and short out.
cant remember if the fender has to come off though since my fender was already off because of the repairs I was doing.
It may be easier for you to drill a hole.
Old Feb 13, 2003 | 11:19 AM
Gjohnson's Avatar
OK thanks guys, I will try to find the hole that Matt was talking about, hopefully I can do a clean install without drilling. If not I'll have to invest in a drill.
Old Feb 13, 2003 | 09:59 PM
Matt93SE's Avatar
STFU n00b!
it's easy stuff.. just remove the plastic liner under the left fender and you'll see all of the stuff we're talking about.
Old Feb 18, 2003 | 10:43 AM
makeuw3t's Avatar
where to drill
ok lets say that i decided to drill the hole for the power wire through the firewall, can anyone suggest any good and or easy places to make the hole. pictures would be extremely helpful too!
thanx
ps. i have a 93 gxe.
Old Feb 18, 2003 | 10:53 AM
Gjohnson's Avatar
The whole Matt was talking about worked great for me, You might try locating it. Thanks Matt.
Excalibur23
Oct 13, 2015 04:33 PM
2kmaximel
Sep 16, 2015 03:19 PM
popdedop
Sep 11, 2015 11:17 AM
