Cost of cruise control actuator?
Old Feb 14, 2003 | 03:19 PM
Spipedong90's Avatar
It looks like I need a cruise actuator for my cruise control system. The light comes on when it's engaged but the car just coasts. The actual vacuum chamber mated to the cable works fine, because I can suck on the hose and move the throttle cable. Assuming I just need the little vacuum pump, what should I expect to shell out for it?
Old Feb 15, 2003 | 12:51 AM
drstillpatient's Avatar
Re: Cost of cruise control actuator?
u sure its the actuator? if its setting the cruise speed only...it still needs the actuator to work, which appears to be working. U might wanna check the cruise control buttons on the steering...
i have heard the wires that go into it gets lose over time and needs to be wiggled a bit to get them working again.
Old Feb 15, 2003 | 05:42 AM
nubiannupe's Avatar
OG Maxima.org Member
I just saw one on Ebay yesterday. I don't remember the item number or anything, but I'm sure it'll come up in a search
Old Feb 15, 2003 | 10:48 AM
«§»Craig B«§»'s Avatar
I think it probably is your actuator
I had the same thing where I could press the set button and the green light would come on but it wouldn't do anything to hold the speed
I got mine from Matt when he was parting out his old GXE, but check junkyards around you and www.car-part.com.
You can use one from a GXE on your SE. The cables are a little different, but you can switch that part from your broken on onto the "new" one. It's just 3 or so screws that holds the big part of the assembly onto the metal bracket and then unplug the vacuum line from it.
Old Feb 15, 2003 | 03:48 PM
Re: Re: Cost of cruise control actuator?
yeah here's the link...its from a 93 max...
http://cgi.ebay.com/ebaymotors/ws/eB...category=33595
gavin68
Sep 18, 2021 12:36 PM
tseng1023
Oct 15, 2015 08:30 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
Noela
Sep 26, 2015 08:22 AM
