VE variable intake
Old Feb 18, 2003 | 01:59 PM
gdmaxse's Avatar
VE variable intake
is there any way to adjust what rpm the variable intake switches over
Old Feb 18, 2003 | 02:06 PM
Jeff92se's Avatar
I'm needing a caw
Sure. Why would you want to change it? It's probably at the best point anyway. You would have to hook the existing solenoid to an aftermarket rpm switch.
Old Feb 18, 2003 | 04:57 PM
dmontzsta's Avatar
Ford Only.
Not worth it. Like Jeff said, I am sure Nissan set it how it is for a reason.
Old Feb 18, 2003 | 05:28 PM
gdmaxse's Avatar
ok thanks
Old Feb 18, 2003 | 05:34 PM
dmontzsta's Avatar
Ford Only.
your welcome.
Old Feb 18, 2003 | 07:56 PM
xenome's Avatar
just curious, but do you guys think...
that the VTCs turn "ON" at a certain RPM or what??
'cause I'm pretty sure it's actually that the solenoid TURNS OFF, at 4100rpm which retards the timing of the cam.
the FSM has a beautiful table and graph of this, but I'm recalling this from head... so I could be wrong.
Old Feb 18, 2003 | 08:51 PM
Matt93SE's Avatar
STFU n00b!
don't mess with it. I played around with it on the dyno and did nothing but lose power. $60 in dyno runs to find out that nissan has it set to the best place already.
Old Feb 18, 2003 | 09:17 PM
gdmaxse's Avatar
Matt, what were ur engine mods when u did that
Old Feb 18, 2003 | 10:02 PM
Matt93SE's Avatar
STFU n00b!
CAI and advanced timing.. same mods I still have today.
Old Feb 18, 2003 | 10:25 PM
gdmaxse's Avatar
do you think that the y pipe could change the power curve enough to where adjusting the VI could gain power, i felt that the y pipe raised the power peak significantly.
Old Feb 19, 2003 | 05:41 AM
Matt93SE's Avatar
STFU n00b!
I woudln't mess with it. it MIGHT change the power curve enough to be worthwhile if you were fully modded, but not just with intake and Y pipe.
for the costs involved in moving that rpm around and dyno tuning it so it's right, you can buy a lot of other mods that will give you more power.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
maxima297
Sep 30, 2015 03:32 PM
09maxshawn11
Sep 30, 2015 10:28 AM
MichMaxFan
Sep 30, 2015 09:18 AM
