Wipers quit working!
Re: Wipers quit working!
If you hear the motor still turning, then more than likely, you just broke the weak linkage that Nissan put in there. I have never fixed this exact problem before, but MANY other Maxima owners have.
I once had a problem with the actual windshield wiper motor going bad. I had to replace it and that fixed my problem.
But, I'm pretty sure that the linkage broke or popped out of joint. Take off that black plastic cover on the bottom of your windshield and check it out. It's a very prone problem with Maximas and I'm confident that's your problem since ice and snow was involved.
If you search, I'm sure you will find many other accounts of people having the same problem.
Originally posted by Max240
thanks for replying. i can't hear the motor at all so i think maybe it is the motor. is that very hard to replace? cost? i did do a search but did not get much out of it. again thanks for replying.
i was driving home tonight, it was snowing a little so i tried to turn on my wipers. to my dismay they would not work at all. any ideas?
I got a motor for $25 from Dixon Auto Wreckers via www.car-part.com Works great and fairly easy to install. Kindof have to wiggle old one out then line up rotating arm on replacement to same position as old one you took out and wiggle it in.
Good luck.
If you need a motor, I have one you can have for $25 + shipping.
E-mail @ thehorns@bwr.eastlink.ca
Jeff
Jeff
jerrod99_se-l
Aug 27, 2015 08:27 PM
criminalslang810
Aug 16, 2015 08:12 AM
