Headlight Problems
Old Mar 6, 2003 | 06:36 AM
MaximaBalla's Avatar
Headlight Problems
Ok guys, I just installed another new headlight connector and now one of my Silverstars is bright white and the other light is a dull yellow? Do you think that I installed the connector wrong or do I just need a new wiring harness? Thanks
Old Mar 6, 2003 | 06:59 AM
Matt93SE's Avatar
STFU n00b!
sounds like you've got a bad hwrness or somewhere else along the line.
get a multimeter and check the voltage at each headlight while they're on. that'll tell you more than anything.
Old Mar 8, 2003 | 07:17 AM
Ok, cool, thanks. BTW: I just went ahead and I purchased the APC upgraded wiring harness?
Old Mar 8, 2003 | 09:01 AM
nubiannupe's Avatar
OG Maxima.org Member
Doesn't that harness have a relay on it? Might wanna check that too. Ya never know.
Old Mar 8, 2003 | 09:43 AM
Soul Fly
Dont Buy APC!!
i got an upgraded harness from "Matrix" -- very easy to install. I've got 2 relays (one for each bulb) - i've never heard of a bulb turning yellow....unless you touched it w/ your fingers
Old Mar 8, 2003 | 01:22 PM
boosted6's Avatar
Check your wiring, Im sure you just mixed up one of the wires. I did the same thing when I was wiring a new headlight socket in. On one side the low beam was dimmer and yellow then the other, but when I put the highbeams were on they were both good. So I checked them both with a multimeter and realized that I had mixed up the ground and the lowbeam wires on that one side. Changed the wiring and it was fine.
Old Mar 8, 2003 | 01:35 PM
N34JZ's Avatar
Needs non-Maxima Friends
Originally posted by Soul Fly
Dont Buy APC!!
chances are your Matrix harness is manufactured by whoever makes the apc harness, alot of these import products are this way. They are all made by one company and then re-packaged for each distributor.
Old Mar 9, 2003 | 04:19 PM
But, I made sure and did one wire at a time when I put the new connector in? I think I pulled the wiring a little too hard when I was trying to splice the wire? I think that could be the problem, maybe? But, like I said, I took it one wire at a time? So, I'm pretty sure that I did it correctly?
Old Mar 11, 2003 | 11:02 AM
jkmay01's Avatar
Lil 8
i had the same problem make sure that you have the ground wire is good and not arcing. let me know?
AaronL
Nov 15, 2020 11:52 AM
MaxLife17
Jun 27, 2019 01:37 PM
03VQMAX
Nov 10, 2015 03:39 PM
Vistance
Sep 17, 2015 05:17 AM
mpbclutch33
Sep 8, 2015 06:21 PM
