Before I Attempt This....(N34JZ)
Or DanNY...anyone who had changed their bulbs behind the guages. My friend tried the same thing and then his speedo didnt work. (on a miata)
Any safety precautions I need to take before changing them? I checked Craig's How To site...couldn't find a lot on HOW to remove the guage cluster...I'm guessing it's just screws and clips?
bulb #194 right? Are those the same in our doors, parking lights, gear shift (a/t), and trunk??
Thanks, (sorry if this irritates you d-sta, or anyone else)
Re: Before I Attempt This....(N34JZ)
and as far as taking the cluster out its held in by 4 screws (simple logic when taking the dash apart : pulling a little will tell you where screws are located )
there are 4 #194 bulbs in the cluster.
when you get it unscrewed there are a few harnesses you will have to unplug.
Also, the automatic shifter console is #194.
sweet...how many bulbs fit behind there...2-4 I'm guessing?
SUCCESS....and failure
I got all of them out...and when i finished screwing in the last screw...i noticed 4 more i missed...uh oh.
DAMN..my frickin light meter that controls the contrast is messed up. it's real low.
It was a b!tch to get the actual black ring of the cluster off. (w/ the a/c vents)
yeah, I had to take the cover off the steering wheel and tilt it way down. It still barely fit.
in case this wasn't mentioned already...a/t shifter bulb is also a 194. if ya wanna get real ricey you can change the 194 in the glovebox too.
RealityCheck
Oct 2, 2015 06:34 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
Pied
Sep 26, 2015 03:29 PM
