Computer question
Old Mar 12, 2003 | 08:45 PM
TLM's Avatar
TLM
Computer question
After I open the paneling in the car, do I have to unscrew the computer from it's mounting? Or can I do all the diagnostic tests from the position it's already in?
Also, can anyone tell me how to switch the modes? I'm not quite clear about it.
Old Mar 12, 2003 | 08:49 PM
mtcookson's Avatar
you actually don't have to open anything. just go to the passenger side and you can see the ecu and it's lights from there. i have the codes listed here http://www.nissanx.com/f0rums/thread...703&boardid=37
Old Mar 12, 2003 | 09:13 PM
TLM's Avatar
TLM
Thanks for the codes...
So I look at the computer... will it blink automatically or is there something(s) I have to do to get it to give me the codes? Turn the little circle counter clockwise?
what if no lights blink?
Old Mar 13, 2003 | 12:02 PM
mtcookson's Avatar
if i remember correctly you just spin the screw all of the way to the right (clockwise) and it should give you the read out. (with the key in the on position) i don't have my manual with me right now so i couldn't tell you for sure.
Old Mar 13, 2003 | 01:30 PM
GreenMaxVE's Avatar
To check codes:
1. Turn key to ON position.
2. Turn screw on ECU clockwise all the way, wait 2 seconds then,
3. Turn screw counter-clockwise all the way, count the blinking light on the ECU or Check Engine Light (these are the codes).
4. Turn screw clockwise and back again to erase codes and your done.
5. Make sure screw is turned all the way counter-clockwise when you're done or car will not run right.
Old Mar 13, 2003 | 02:26 PM
medic's Avatar
my 93 FSM says that there is only a single red led. long blinks are the tens, short blinks are the ones. So long, short, short, is code 12
the other post mentioned something about a green LED also. The FSM didn't mention anything about that.
Old Mar 13, 2003 | 02:31 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
thats because that link is only the diagnostic for the VG, the VE diagnostic differs
Old Mar 13, 2003 | 08:50 PM
TLM's Avatar
TLM
All I did today was:
Turn car to ON
Turn the screw counter clockwise
Then there were 2 long red flashes, followed by two fast red flashes.
That's all... what does that mean? I'm new to (fixing) cars, so even with everyone's help I still feel sort of lost.
Old Mar 13, 2003 | 09:07 PM
DA-MAX's Avatar
the VE codes are totally different form the VG so i have no idea, you need to hop on Ebay and buy yourself an FSM all the codes and procedures for the VE outlined to a tee.
Turn car to ON
Old Mar 14, 2003 | 06:29 AM
jwagen02's Avatar
According to the Chilton's Book, Code 22 is: "Fuel Pump Circuit (to 1991)
I went to my local public library and checked out the Chilton's Manual to help me with my 92 SE. Could be a faster/cheaper option than buying one off of ebay...
Old Mar 14, 2003 | 07:19 AM
TLM's Avatar
TLM
Any idea why it would have flashed red instead of two reds and a two greens?
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
Socalstillen
Sep 26, 2015 12:01 PM
