motor mounts
Old Mar 13, 2003 | 04:00 PM
mtcookson's Avatar
motor mounts
What was that new polyurethane stuff that people are using on motor mounts. I think it was a 3m pre-mixed polyurethane.
Old Mar 13, 2003 | 04:37 PM
mtcookson's Avatar
no one?
Old Mar 13, 2003 | 04:39 PM
JDwyer2821's Avatar
Originally posted by mtcookson
no one?
3m makes some good ****
Old Mar 13, 2003 | 05:01 PM
mtcookson's Avatar
yeah, there stuff is pretty good.
Old Mar 13, 2003 | 05:11 PM
mtcookson's Avatar
is 75 durometer good for motor mounts?
Old Mar 13, 2003 | 05:38 PM
Sudesh's Avatar
i don't currently have the part numbers, but mcmaster.com sells 80 and 90. This comes in two parts which you mix together yourself. It's up to you how stiff you want the mounts, I would go with the 90. Most people go with either 80 or 90.
Old Mar 13, 2003 | 05:40 PM
mtcookson's Avatar
thanks! i searched through here and finally found something, control+f works wonders. they have many different durometers. i'll be going with 94. here are the links i found http://www.nx2k.com/nx2000/hd_mounts.htm
http://www.geocities.com/CapeCanaver...-r/mounts.html
http://www.mcmaster.com/
Old Mar 13, 2003 | 09:59 PM
Matt93SE's Avatar
STFU n00b!
I would stay with stuff in the 80s. the 90 is just too hard.. almost plastic.
the 87 or whatever I'm using now is so hard that the whole car shakes at idle. didn't feel a thing with my brand new OE mounts, or even my ooooold OE mounts. only with the urethane.
Old Mar 13, 2003 | 10:10 PM
Aaron92SE's Avatar
NWP Engineering.com
Have you used both or seen how hard the 94 gets? I'm seriously going to do this and I have my mind set on 94 just b/c I am a freak. I want to feel the vibrations of my motor. For instance, my VB mod... it never gets old. And the people that have ridden in my car can vounch for it... it's a MEAN shift. I absolutely love it. That is why I think I would love very firm mounts. I'm just scared that 80 won't be enough. I'm not scared that 94 will be too much.
Matt, what do you think? I think I would like it if I just get rid of my mounts and weld the motor to my frame.
Old Mar 14, 2003 | 12:40 PM
mtcookson's Avatar
hey matt, did you fill yours or completely hollow them out and fill them from there? would it make much of a difference if you hollowed it out and filled it with the 80 compared to just filling it without hollowing it?
Old Mar 14, 2003 | 02:38 PM
Matt93SE's Avatar
STFU n00b!
James, the rubber in the mounts from the factory is (just a wild guess, but you get the point) about 40 durometer. you can easily shove your thumbnail into it.
with the 80 durometer I used, the stuff is hard enough that I can barely put an indention in it with my thumbnail when I press so hard it's hurting..
the 94 is another step past that I and I highly doubt if it will make any difference, other than to make the ride even harsher.
As for how much I filled, I removed ALL of the rubber inside using blowtorch, grinding stones on a grinder, wire brush, etc etc. there was hardly any rubber left- showing metal over about 80% of the surface.
Old Mar 14, 2003 | 07:15 PM
89sks's Avatar
Sounds like you guys are repairing the existing mounts somehow, is there are writeup on how to do this? I am guessing that this procedure is either easier than replacing the mounts or your going for the firmer mount? I think mine might be going bad, when I shift into drive the whole car shakes and especially the rear deck vibrates like heck. Does that sound about right? Any help is appreciated!
Old Mar 14, 2003 | 07:26 PM
subs1000w's Avatar
is it the harder the urothane to better it controlls wheel hop because i get really bad wheel hop and would like to put an end to it with this or a there other things
Old Mar 14, 2003 | 10:10 PM
Matt93SE's Avatar
STFU n00b!
there's about 500 things that will help wheel hop. new struts are the most important. engine mounts also help.
89sks, do a little reading on urethane engine mounts. there's a TON of info out there, on this forum and dozens of others.
Old Mar 15, 2003 | 06:36 AM
mtcookson's Avatar
those links i posted above will take you to some website that kind of show you what to do.
AaronL
Aug 8, 2020 10:31 AM
D Mason
Jun 21, 2016 04:43 AM
Unclejunebug
Apr 2, 2016 05:42 AM
knight_yyz
Nov 1, 2015 01:34 PM
