I Dont Know What The He// Is Going On
Old Mar 13, 2003 | 07:55 PM
my2ndmax's Avatar
Tonight when I got off of work I started driving home half the way there I turned on the heat in the car as soon as I did I got an even rougher idle and when I hit the gas my rpms went a little higher than usual before the car picked up speed but as soon as I turned the heat off everything went back to normal has anyone experienced this or does anyone know whats wrong. Any and all help is appreciated. Thanks
By the way its a 92SE Auto.
Old Mar 13, 2003 | 08:28 PM
MaDMaX024's Avatar
sounds like your electrical system is being very loaded...alternator problem maybe? check your grounding points..thats where i'd start.
did the lights dim at all?
Old Mar 14, 2003 | 07:23 AM
my2ndmax's Avatar
No the lights didnt dim at all.
Old Mar 14, 2003 | 07:55 AM
MaDMaX024's Avatar
hmm, thats baffling..about the only advice i can give is to clean all battery and ground connections and see what happens..i'm interested to see what the problem is if that doesn't help.
Old Mar 14, 2003 | 08:05 AM
CandiMan's Avatar
Say Candyman 5 times
Did you happen to have it in defrost mode for the windsheild. If so the ac compressor will kick on also even with the temp gauge handle all the way to hot. Does it happen all the time or just that one time?
Old Mar 14, 2003 | 08:08 AM
my2ndmax's Avatar
Yes I did have it in defrost mode. This is the first time that I noticed it happening.
Old Mar 14, 2003 | 09:52 AM
MaDMaX024's Avatar
hmm, i never thought of that. i guess its because i took my AC belt off..
Old Mar 14, 2003 | 10:03 AM
Jeff92se's Avatar
I'm needing a caw
Anytime you activate the defrost, it engages the AC compressor to dry the air. Since the AC puts a load on the engine, the ecu tells the engine to speed up the idle(to prevent the car from stalling)
If your idle air control system is suspect, it might stumble when you engage the compressor
