Another Wheel Bearing Question
Old Mar 15, 2003 | 10:41 PM
MadMax92's Avatar
is there any way around using a press like a copper punch and hammer? I didn''t think so, but i thought I'd ask. Anyway HOw much would it cost to get them put in? just an Idea please.
Old Mar 16, 2003 | 12:22 AM
JESSE93SE's Avatar
yes you can
I recently replaced the left front wheel bearing in my 93se.
i used a steel punch and a vice to hammer it out, then took some
sand paper to smooth out the inside to carefully and very slowly
pound the new one into place.
the bearing race(sp?) was a SOB to get off the spindle. i first tryed prying, then a torch, and then finally after a broken pry bar i ended up cutting it off with a grinder.
just strong accurate hits with a hammer and punch will get it done.
it would be adviseable to buy both seals (inner and outer) for the job(they are both the same).
any more questions let me know
jesse
Old Mar 16, 2003 | 11:24 AM
chrispy's Avatar
now that sounds like a good time in the shop
Old Mar 17, 2003 | 05:00 PM
MadMax92's Avatar
Re: yes you can
jesse
thanks man
Old Mar 17, 2003 | 09:04 PM
Matt93SE's Avatar
STFU n00b!
do NOT use a hammer and punch to change the bearings.. it's one thing to remove the old one that way, but not to replace with the new one.. a shop will charge a $10 bill or so to press the new one in. much cheaper than replacing the bearing again in a few thousand miles because you were too cheap to have it done by the proper equipment.
Johnny9595
Sep 3, 2015 05:18 AM
seesole
Aug 26, 2015 11:22 AM
Flores94
Aug 11, 2015 12:53 PM
FanaticMadMax
Aug 10, 2015 08:55 PM
