Can you test the TPS
Old Mar 17, 2003 | 06:36 PM
TLM's Avatar
TLM
Does anyone know of an easy way to check if the TPS is functioning correctly?
Old Mar 17, 2003 | 06:45 PM
Sudesh's Avatar
disconnect it and rpm should drop. proper way to test would be to check the voltage.
Old Mar 17, 2003 | 09:14 PM
TLM's Avatar
TLM
Do you know of any sites that would show me how to check the voltage and what it should be?
thanks
Old Mar 18, 2003 | 06:03 AM
rjgreen1's Avatar
I would like to know also
Old Mar 18, 2003 | 07:09 AM
subs1000w's Avatar
you check the voltage between pins 1 and 2 on the conector it should read between 0.4 and 0.5 volts at idle and 4 volts at wide open and you do this with the car off but the ignition on. i did this last week and mine was at 0.7 at idle and 4.2 at wide open so i just loosed the 2 bolts that hold it on the tb and ajusted it till it was at 0.45 volts at idle and then tightened the bolts up and it was at 3.99 at wide open PERFECT but i didnt notice any diference so i dont think it has to be perfect
Old Mar 18, 2003 | 07:26 AM
rjgreen1's Avatar
Thank you
Richard
tarun900
19
Dec 20, 2021 06:57 PM
knight_yyz
Nov 1, 2015 01:34 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
