miles going down down down
Old Mar 25, 2003 | 12:26 AM
redzero's Avatar
for some reason i'm not getting as much as i used to get on a full tank of gas. right now i barely get 125 miles on a full tank of gas. what could be the problem?
Old Mar 25, 2003 | 05:55 AM
D-sta's Avatar
tune up
Old Mar 25, 2003 | 01:23 PM
92vemaxse's Avatar
WOW! That's really bad... what D-sta said, try a tune up, possibly a chunk of wood under the accelerator pedal...
Brian
Old Mar 25, 2003 | 09:02 PM
Matt93SE's Avatar
STFU n00b!
probably a dozen or so things wrong with that car, aside from the hole in the gas tank.. take it to a shop and let them work with it for a while.
Old Mar 26, 2003 | 04:29 AM
Fredrik's Avatar
Re: miles going down down down
Air filter andd spark plugs might do the trick
Old Mar 26, 2003 | 12:03 PM
adamis's Avatar
That's gotta be a record for the lowest miles on one tank of gas. Heck that thing is drinking almost 4 times the amount of gas then it should. Does the car even run good? I would think it would be running so rich it would hardly move.
If it's running smooth then I'm with the idea of a leak in the fuel line somewhere. If the car is parked outside and its hot then you might not be able to see a puddle as the gas evaporates to fast.
Old Mar 26, 2003 | 02:35 PM
Matt93SE's Avatar
STFU n00b!
only time I've ever got under 200 miles on a tank was when I went on a "spirited" drive through the N. Georgia mountains at Maxus 2000. four hours of sliding sideways through corners, up and down hills, and I still got over 200 miles on that tank.
there's a lot more wrong than spark plugs and air filter. they'd be the top of the list to change, but it's also got a lot of other problems.. sensors, vacuum lines, plug wires, distributor cap and rotor, etc etc.
Old Mar 26, 2003 | 09:06 PM
redzero's Avatar
Old Mar 26, 2003 | 09:15 PM
Matt93SE's Avatar
STFU n00b!
it's called normal maintenance. start performing it, and your car will love you long time.
Old Mar 27, 2003 | 08:26 AM
nstymax93's Avatar
hey quick question while on gas milage. If you advance timing like how Craigs site says to, do you need to run 93 octane from that point forward? I heard you did, also what happens if you dont? Also will gas milage go down a little bit?
-Mike
Old Mar 27, 2003 | 09:59 AM
92vemaxse's Avatar
-Mike
Well, it doesn't matter if your timing is advanced or not, premium gas should still be used in your max.
Yes your gas mileage will go down. After seeing how much faster your car will be will make you drive faster; kinda like the first two weeks after you add another mod.
Old Mar 27, 2003 | 10:35 AM
nstymax93's Avatar
Thanks, thats what i thought. Since advancing my timing i get around 325 mpg and before that i would get about 340 mpg which isnt that big of a difference.
-Mike
Old Mar 27, 2003 | 12:23 PM
adamis's Avatar
Premium Fuel? I haven't used premium fuel in my car ever and I have never had a problem. I also get at least 400 miles to a tank, usually 450+. Just had my car smogged and found my timming to 17 degrees to. Of course with the type of blend they mix up here in California and at the price they sell it the gas should be premium.
From the stuff I have read you only need to run premium fuel if your car has detonation issues. There is no other benifit to running it. It is not any "cleaner" then regular fuel, it is just a blend that ignites at a higher temperature.
Fuel that ignites at a higher temperature will actually put out less energy overall then a fuel at a lower temperature. Just consult your T-s diagrams from Thermodyanamics and you'l see what I mean. It is all about the area under the curve. This is of course comparing two indentical engines and not the difference between an engine with advanced timming or boosted and one that isn't.
Old Mar 27, 2003 | 01:45 PM
Tall's Avatar
I run regular in mine as well and never have had any engine troubles. I get 400 miles in the city, 500 on the freeway on a tank. 125 miles? Are you towing 5000 pounds?
Old Mar 27, 2003 | 08:56 PM
Matt93SE's Avatar
STFU n00b!
you should run at LEAST 89 octane in the VE due to the higher compression. VG engines don't care much. if you advance your timing, then you need to run even higher octane. I run 93 in mine with advanced timing and sometimes get detonation on really hot days in summer.
Old Mar 27, 2003 | 11:11 PM
Aaron92SE's Avatar
NWP Engineering.com
How can you tell you're detonating? The KS should fix that before you hear any pinging.
Turbonut
46
Oct 21, 2015 08:28 PM
JoshG
51
Sep 21, 2015 10:41 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
Socalstillen
Sep 20, 2015 11:46 PM
hntwhttail
Sep 12, 2015 03:43 PM
