Who bought Cams?
Old Jan 15, 2001 | 03:23 PM
Tonio90max's Avatar
I was wondering who bought cams from Cattman or JWT, because I just purchased the last set from Cattman, and I was also wondering if everyone could give feed back once everything is installed.
Does anyone know how much it will cost to install the cams?
Old Jan 15, 2001 | 04:42 PM
SkyMax's Avatar
Cams aren't easy to install for beginners. You need to remove the intake manifold and then you'll need to work your way into the engine and remove the cams and replace them with the new ones. This is one of those mods where you don't want to make any slight mistakes! I was tempted to buy the Cams but I have no use for them. I was reading your sig and your max has some nice mods. Do you have any pics?? If not, can you get some pics for us?? Thanks
Old Jan 15, 2001 | 04:48 PM
Foo90SE
On the VG motor i believe you have to remove the heads, or pull the motor to get the cams out since they slide in the head. So it would cost a good bit for installation.
Old Jan 15, 2001 | 05:43 PM
Maximamike's Avatar
You're in Mass right? Maybe we can get together after you install them for some movies, pics, etc. There should be another Mass meet this spring.
Old Jan 15, 2001 | 06:11 PM
Tonio90max's Avatar
Atlanta, Ga
I would like to post an pic. of my car but I don't have an scanner.
Old Jan 15, 2001 | 06:22 PM
Foo90SE
You're in atlanta? im in marietta just above atlanta...how much did rebuilding your motor cost? Did you do the labor yourself? I would just need the parts prices because i can do the labor in my school's shop.
Old Jan 15, 2001 | 07:29 PM
Tonio90max's Avatar
It was an total rebuild with no special components but I did get it polished and ported w/ the TB also I payed $3500.
Did anyone buy these cams, I'm really hoping that I will gain some serious HP.
Nismo87 is the only person who had cams and wonder what type of result he noticed before his engine died.
Old Jan 15, 2001 | 08:36 PM
Nismo87SE's Avatar
From my brief experience 40 miles . I can say that the cams + headwork kicked so much *** . My car pulled to 6500rpm with no problem. Also I had the ISKY 262 cam which is a mild cam upgrade compared to the JWT cams. I could feel the difference in power after 5000rpm vs stock cams/heads. I had more torque from 4000-6600rpm. Then I was fully able to take advantage of my Protorque TC. Although I didn't do any hardcore standing start launches, with just 60% throttle the car was jumping off the line. Then the cams + heads would finish off what the TC started. The JWT cams should have more midrange and toppend torque than the cams I had on my max. Also you should replace both your camshaft front oil seals and timing belt/tensioner, since you have remove it anyway. The install is a very, very big PITA. There are only 2 ways, pull the motor or pull the heads to install cams. The cheaper/easier way is to pull the motor so you can slide the old cams out. Otherwise you'd have to buy new head/intake manifold gaskets if you remove the heads. But if the VG cams are as good as the SR20DE cams from JWT are. I have a feeling you'd have a pretty good smile on your face once you open it up in 3rd gear.
Old Jan 15, 2001 | 08:49 PM
Tonio90max's Avatar
for reply to the post. Your feed back is very helpful and I'm very anixious to these cams in.
I know your engine is gone, so are you going to rebuild or rebuild w/ an turbo.
Did anyone buy these cams no one's repling?
Old Jan 15, 2001 | 08:56 PM
Tonio90max's Avatar
NISMO87
Did the ISKY Cams have anything to do with your engine missing up.
If not what happen to it?
Old Jan 15, 2001 | 09:00 PM
Matt93SE's Avatar
STFU n00b!
How much did you pay for the cams?
I'm thinking I may do this as a summer project after I get my seats and interior done.
Old Jan 15, 2001 | 09:07 PM
Tonio90max's Avatar
I payed $545
JWT is sold out! You may want to try Cattman they may have one left. Both companies got the cams from Japan and will not recieve anymore, they stopped making them.
I really didn't have the $$$ but I had to have them.
Old Jan 16, 2001 | 05:44 AM
flyry110's Avatar
Re: I payed $545
any of you guys know if you can get lobey cams for a VE motor? also, do you adjust the rockers and valves like on a GM motor or do you need nissan special tool #3,938,387?
Old Jan 16, 2001 | 10:03 AM
Nismo87SE's Avatar
Re: NISMO87
Nope my engine died because the headgasket blew. It also appears that my front cylinder head has a crack around the #2 spark plug hole.
Old Jan 17, 2001 | 11:57 AM
flyry110's Avatar
Re: Re: NISMO87
sooooooooooo, i can't get cams for my VE?
Old Jan 17, 2001 | 03:32 PM
Tonio90max's Avatar
NO
I don't think anyone sells cams for a VE but I' sure you can get your cams regrind at a machine shop.
Old Jan 17, 2001 | 05:26 PM
Nismo87SE's Avatar
Re: Re: Re: NISMO87
Yes you can get cams however, they will have to be regrinds. So you should order new cams from nissan then send them to ISKY or crower to get reground.
spazma7ik
Jan 12, 2017 09:38 PM
gustavison
Oct 4, 2015 06:50 PM
Max139617
Sep 29, 2015 06:44 PM
conansriver
Sep 11, 2015 10:26 AM
Violator
Sep 9, 2015 10:14 AM
