custom trunk pics?
Old Mar 26, 2003 | 03:53 PM
maxinmaxima's Avatar
custom trunk pics?
I'm redoing my stereo for the summer, I want my subs and amp to take up less space, just wondering if anyone had pics of their customs setups? any pics would be helpful and much appreciated
thanks
Old Mar 26, 2003 | 04:17 PM
Chupacabrą
[IMG]http://images.cardomain.com/member_img_a/155000-
155999/155145_104.jpg[/IMG]
Old Mar 26, 2003 | 04:33 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
for larger versions of those pics and quite a few more check out my site
http://maxima.cardomain.com/member_p...=155145&page=5
i'm actually redesigning it again
Old Mar 26, 2003 | 04:54 PM
do you have any problems with moisture in the cap or amp having them in the wheel well?
Old Mar 26, 2003 | 06:18 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
amp isn't in the wheel well and i do get moisture in there...
the amp is actually mouted above the box if you look closely at some of the later pics...
Old Mar 27, 2003 | 06:21 AM
Mike92GXE's Avatar
Got Beat?
For now i have two 12s in a custom box and then covered with a custom panel so that the haters won't be "all up in my ****" when i need to get something out of the trunk. Its made of wood with the area in front of the speakers cut out and covered with carpet.
Old Mar 27, 2003 | 06:30 AM
Shugarhi's Avatar
Re: Got Beat?
not exactly a space saver, but its an idea
this is the only pic i could get to fit
Old Mar 27, 2003 | 06:54 AM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
man i'd go nuts w/o the trunk space hence my setup... looks nice though
Old Mar 27, 2003 | 08:56 AM
89sks's Avatar
Anyone ever mount a 10 or 12 sub in a box that had the same width and height of the panel mounted to the back of the seat with a corresponding depth to acheive the correct amount of volume while having the entire enclosure bolted to the rear seat crossmembers with sub facing and firing through hole where the armrest folds down? This was an idea I had as I wanted to maintain as much trunk space as possible. Not sure if my run on sentence made any sense though.
Old Mar 27, 2003 | 10:07 AM
Shugarhi's Avatar
i think matt did that, and i've seen a couple 4th geners do it as well
Old Mar 27, 2003 | 12:31 PM
89sks's Avatar
Cool, which Matt did that, I'd like to check it out if he has a homepage or something.
Thanks!
Old Mar 27, 2003 | 03:18 PM
Shugarhi's Avatar
Thanks!
matt93se?
REDinLV
Aug 15, 2024 12:30 AM
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
bigfrank
Oct 1, 2015 12:51 PM
