Brakes
Old Mar 26, 2003 | 08:37 PM
Tom's Avatar
Tom
Brakes
I will do a major brake job on my car soon (new rotors and drums).
I'm pretty much stuck when it comes to the rears, so I'll just go with stock drums with shoes.
For the front, I have some choices so I thought I'd ask what you all did for brakes. I am thinking Brembo replacement rotors with Hawk pads. I thought about cross-drilled rotors, but not sure if I will have any benefit in everyday driving (I drive pretty conservatively).
Old Mar 26, 2003 | 09:03 PM
Matt93SE's Avatar
STFU n00b!
you can convert the rears to discs, but unless you drive like a madman (like me), then you don't need the benefits.
for pads, I highly recommend Raybestos Quiet Stop or Bendix IQ. they're fairly cheap and good performance and quality.
rotors, I only recommend Brembo or OEM rotors. don't go with slotted or drilled, they'll only give you the potential for problems.
Old Mar 26, 2003 | 09:28 PM
tafan321's Avatar
matt , is there a howto to convert them over?
Old Mar 26, 2003 | 09:42 PM
Matt93SE's Avatar
STFU n00b!
yup... read the FAQs at the top of the page.....
or go to www.4dsc.com/articles
I wrote 'em both.
(the articles in question, anyway)
Old Mar 26, 2003 | 10:41 PM
tafan321's Avatar
aight thanks man
Old Mar 27, 2003 | 02:26 AM
EdzMax's Avatar
Hey Matt, I have to ask, do the Maxi in the states have drum rear brakes? I thought all Maximas comes with discs all around. My Maxi has all discs standard. I guess it must be a Japanese thing.
Old Mar 27, 2003 | 05:13 AM
nismo1989's Avatar
GXEs come with drums...
Hey Matt, did you ever end up installing any type of brake proportioning valve? I would search but I can't
Old Mar 27, 2003 | 05:20 AM
Pervis Anathema's Avatar
I know for a fact that the 89-91 GXE models came with rear drum brakes. However, I think that the 92-94 GXE models with ABS have rear disc brakes. Anybody know for sure?
Old Mar 27, 2003 | 05:22 AM
Re: Brakes
Take a look at PFC pads. They are $32.99 from Autozone with a lifetime warranty. Next to EBC greenstuff, these are the bests pads I have ever used. And when they wear out, just take them back for a new set.
Old Mar 27, 2003 | 08:59 PM
Matt93SE's Avatar
STFU n00b!
US-spec GXEs had drum brakes, unless they had ABS.. Otherwise, all non-US spec GXEs had discs in the back.
ALL SEs reguardless of ABS or not had discs.
No proportioning valve. you don't need it. the master cylinder is the same for discs and drums..
Old Mar 27, 2003 | 10:07 PM
crazy4maxima's Avatar
I have the blendx import quiet.. its good.. and for the front just go with oem or blank disks from brembro..also while your doing your brake job, bleed your brake lines.. i still have to do that...
Old Mar 27, 2003 | 11:04 PM
D-sta's Avatar
I can't believe your boy Jeff didn't do that. He did the brake job it only takes a few minutes especially on the lift to do.
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
