A couple of questions
How much should a junk yard charge for a '90 GXE gauge cluster that I would remove myself? He's telling me $75, is that reasonable? And a second question: How do you remove the rear lens piece between the taillights? Is it bolted on? Thanks in advance.
Re: A couple of questions
that isnt too bad.. i think you could get a better deal but that isnt too bad for the gauges. and i believe its bolted or screwed on to the trunk lid. if you look on the inside of the trunk lid you will see the carpet stuff if you pull that off then you should see some bolts or screws.. good luck
Mar 12, 2020 12:06 AM
Violator
Sep 9, 2015 10:14 AM
