Key broken in the door.. how to get it out? Help
Old Mar 27, 2003 | 10:03 PM
crazy4maxima's Avatar
WEll after 12 years of use.. my key finally gave out.. funny thing was that i put the key into the lock and turned it and the lock opened. I was taking the key out the hole and it broke as i was taking it out.. thank god for the key pad keyless entry, which is what i use now to get in the max.. also thank god for a copy of the key.. when i purchased my max about 2 years ago i made 3 copys of the master key... i always carry a spare just in case.
any how is there anyway i can get that broken key out? Can i take the cylinder to the lock smith and have them take it out...?? what are my options.?
Old Mar 28, 2003 | 03:47 AM
N34JZ's Avatar
Needs non-Maxima Friends
drive to a locksmith, Im sure they could take it out. Depending on where it broke you could probably get it out your self with some tweezers and other small tools
Old Mar 28, 2003 | 05:49 AM
my2ndmax's Avatar
I would try some tweezers and toothpick. Thats what I used to get mine out.
Old Mar 28, 2003 | 06:12 AM
D-sta's Avatar
Damn a toothpick, what kind of material is it made of. I would think that it would break easily in the process of trying to get the broken key out.
Old Mar 28, 2003 | 07:06 AM
DanNY's Avatar
Ad·min·is·tra·tor
take the lock cyl out.
use the weapon of choice to push the slug out.
reinstall lock cyl.
sit back and enjoy a brew.
Old Mar 28, 2003 | 01:31 PM
avusblue92se's Avatar
broken key
I had this happpen to me in my ignition a couple of years ago. I called a locksmith, and they came to my house to fix it. I think it was around $50. Good luck.
Old Apr 13, 2003 | 09:52 PM
4DSC1989's Avatar
Re: Key broken in the door.. how to get it out? Help
If you take a medium sized safty pin (not a needle, needles are hardened and will break) and a pair of pliers, Use the pliers to bend the last 16th of an inch of the pin into a hook. You can then fish the end of the key out with the hook. You might want to write down the four digit code on the side of your old key. The dealer can cut a new key with the numbers. You can use the same numbers to make a valet key, you just need a valet key blank.
litch
123
Jan 4, 2024 07:01 PM
tarun900
19
Dec 20, 2021 06:57 PM
Fbana41
Aug 29, 2016 12:18 PM
jerrod99_se-l
Sep 19, 2015 06:54 AM
