IS it possible for the ECU to retard the timing?
Old Mar 31, 2003 | 09:23 AM
doomtoo's Avatar
A hypothetical question, if you changed your spark plugs, and something really nasty got in there, like a leaf or something, and there was some detonation. Could the ECU retard the timing?
If you have some unknown problem with your car(could be an injector, could be cat, could be compression, ect, ect), would an engine diagnostic help you solve what it is?
Old Mar 31, 2003 | 09:31 AM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
Re: IS it possible for the ECU to retard the timing?
in all of your threads so far you keep implying this...did you actually drop or let something fall in there??
and yes I'm pretty sure if there is detonation the sensor pikcs it up and retards accordingly.
Old Mar 31, 2003 | 10:20 AM
lophix's Avatar
Re: Re: IS it possible for the ECU to retard the timing?
lol i think he did...probably in the rear
Old Mar 31, 2003 | 12:42 PM
doomtoo's Avatar
Well, I don't think I did, but there's a very good chance of it, becuase all around the spark plugs was alot of junk and little things. I know know you can use a bicycle pump to get rid of that...
I haven't been implying that in ALL my posts... just the more recent ones :S I think it's an electrical problem(although it might not be) and the only info I've gotten so far towards that lead, is that the timing may be off. It would be one possible explanation at why the car is runnning very rich...
Old Mar 31, 2003 | 11:03 PM
adamis's Avatar
I have a ton of junk all around my spark plug wells. One time I almost had a tiny washer from who knows where fall inside the cylindar. For some reason I decided to get a flash light and look before took the old spark plug out.
As for debris and stuff I think most of it that is not non metal like leaves and stuff will just burn up and turn to ash. My guess is ash won't have to hard of a time finding it's way through the exhaust system with little harm done. It won't be the best for the car but I don't think it will hurt it. This is all dependent on just how much debris actually got inside the cylindar of course.
cruce91
Sep 20, 2015 10:23 AM
intimidator
Sep 5, 2015 07:23 PM
Slamrod
Sep 3, 2015 07:38 PM
t6378tp
Aug 24, 2015 07:03 AM
