ATTN: srmtn Re: 5sp. trans. fluid check...
Old Jan 16, 2001 | 05:59 PM
Czar's Avatar
Your check/fill hole is on the front of the transmission towards the driveer's side end of the tranny. The plug uses a 1/2 inch drive socket wrench without the socket to loosen. when you stick your finger into the hole, your fluid should be up to the edge of the hole with the car level. If your trans. fluid is low, you most likely need a fluid pump to get trans. fluid into the trans. through the fill hole. If you wish to drain the trans. the drain plug is on the side facing the engine towards the back of the trans. just forward of the shifter linkage. It is a 12 mm plug. Careful not to mess with other bolts on the trans. because that could cause you to have to take out and disassemble your trans. to repair it. Hopefully this information can help.....
Old Jan 17, 2001 | 09:18 PM
Maxmann's Avatar
Thank you very much for the info. I'll check it out. Thanks, again! srm
Old Jan 17, 2001 | 09:22 PM
Maxmann's Avatar
...question...do you standard transmission fluid to replace, if necessary? srm
user 11122324
42
Jul 18, 2022 03:35 PM
fastcarny
Oct 12, 2015 07:06 AM
Need help
23
Oct 2, 2015 08:56 AM
Maxxx10
Sep 13, 2015 03:16 PM
