Manual Transmission Swap Update.......
As some of may remember, my auto transmission is dying on me and I need a new a tranny so I checked on the org and have found out that converting to a manual could be the cheapest way and most affective mod that I can give my 89 Max SE. I took it to the transmission shop and talked to the guy there about the manual swap and he told me the best thing to do if I were to do the manual swap was to get a wrecked Maxima for cheap that has a good tranny in it and pick it up and take it to the tranny shop and then they can switch in the manual into mine and the auto in mine, out. Now the labor of this is not cheap, $1500 for it and the $500 for the junked Maxima. So i'm looking at about a $2K job when it's all done but my dad and I are gonna check out the junked Max in a few days to see when were gonna pick it up, so it should all be done in a couple of weeks. Thanks for all the help that you guys gave me, it got me headed in the right direction .
Originally posted by James92SE
Why arent you doing it yourself?
Re: Manual Transmission Swap Update.......
1.) is the junkyard giving a warranty on the tranny?
2.) how many miles on the odo?
3.) what year max is it coming out of?
i went to a yard last week and found about 3 manual third gens and 2 second gens. was quoted at 550 for the tranny (91 max with 200K miles). don't know if he warranted it or not, but it did go into all gears (a little tough into reverse). he said he would take 600 for the tranny and the miscellaneous parts for the swap.
i just thought i'd share my experiences. haven't bought the parts since my auto still works i guess. good luck with your swap!
I just paid $2200 with rental cars to get the swap done, and I had the donor car. Then the trans just went out, stay away from yard trannies, or get it fully rebuilt, I am having a full overhaul done, with new gears and all...I am not going through this again...$4k just for a 5 speed.
Re: Re: Manual Transmission Swap Update.......
Originally posted by ghostmax
if you don't mind my asking,
Re: Re: Re: Manual Transmission Swap Update.......
92 GXE I think. On the research that I found, all 3rd Gen's match up so i'll let the tranny place do all the work. It's a private seller but the transmission place said that they would replace anything that needed to be replaced.
Dmontzsta, sorry to hear about that. Did the yard's tranny go into gears, check out fine when you bought it? About how many miles were on it? It's impossible to know the history of a vehicle in a yard. Let the buyer beware!
Re: Re: Re: Re: Manual Transmission Swap Update.......
SE? Only SE's had the manual trannies. If you're getting a tranny from a 92-94, then you might have to get additional parts such as driveshafts and maybe different mounts. 85-91 should be a direct swap with 90-91 trannies having upgraded/better quality internals.
well
89-91 gxe had manual tranny that would bolt up to any vg engine
92-94 VE SE 5spd are compatiable with its own VE engine.
the 92-94 GXE had a vg engine with auto only.
92-94 SE VE cam in both auto and 5spd.
Originally posted by crazy4maxima
well
well
well
well
Originally posted by AET
The 5-speed VE tranny has limited slip differential, 5-speed for VG doesn't. So at the very least you're gonna have to get new axles. I thought the bolt pattern was different from VGs to VEs, but perhaps I'm wrong.
Hey man, just called my friend Barry who is the parts manager at the Nissan dealership in Lexington. He said that the parts # for the two trannys are different, and that more than likely they are not compatable. However, he did say that the bolt pattern might be the same, that the VE tranny MIGHT bolt up to a VG motor--- just because the part numbers are different doesn't automatically mean it won't work. He DID say that regardless, the VE tranny has limited slip, whereas the VG tranny does not. He said he is positive that because of this you would have to replace the axles if you did get a VE tranny to work-- no question about it. I remember seeing a post dealing with the VE/VG 5-speed compatability issues when I searched a few months ago. The conclusion I gathered was that they are NOT interchangable. I remember that one of the moderators had a for sure answer on this one, don't remember which. I would try pm ing one of the moderators--- matt93se would be a good one to try, he seems to be a walking, talking FSM. If he doesn't know, I'm sure he can tell you who does.
Originally posted by dmontzsta
you guys are all dumb, there is someone on this board driving his 93gxe with a VE VLSD tranny. now what?
i know someone exchanged the "diff" from VE to VG..but not the entire deal.
WE'RE ALL DUMB? This from the man who spent $4,000 on a tranny swap for a GXE w/ 260k? Come on man, you could've had a SE 5-speed in good shape for less than you spent on your ham fisted conversion! If you'de done that, you woulda had SE w/ better suspension, less milege on the car, and wouldn't need to vent your anger at people who are trying to help this guy. I think next time you decide to call EVERYONE stupid, you ought to think about how stupid your own choices have been, and think about how many org members read your post documenting your own stupidity! Now think about how nobody got rude with you, probably because most people on this site want to help one another, not talk smack out their *****! Especially from the crown prince of botched tranny swaps!
go run and play...dont try and tell me how to spend my money.
VE 5 speed SE POWER!
Don't give a mad foalk how you spend your loot, you obviously got more $$$ than you do either brains or courtesy! The point is try to help this man, not talk s***t. Just because your cars pimped out doesn't mean you know s**t from tar about this man's problem! By your own admission you got caught in a bad situation w/ your tranny, so why don't you offer something a little more constructive than, "You're all stupid." Have some humility you arrogant $#$%, this guy's trying to avoid something akin to what you did to yourself! This guy is taking the time to do his tranny right. He's trying to get answers so the job gets done right the first time, unlike some people.... Few people on here are Nissan mechanics, so most people are trying to help each other the best they can. Maybe you don't agree with everything you read, thats fine, I don't either. Doesn't make whoever posts it stupid. Just have a little courtesy man, people are only trying to help. And BTW, I might be a noob, but I knew before I bought my Max I wanted a 5-speed, so unlike you I haven't had to **** away the price of another car just to make it that way!
Glad to hear it. I agree that anything's possible, hell, swapping from auto to stick proves people will go through alot to have their Maxs the way they want them. I didn't know you were trying to help the man outside of the web, I think thats good s**t. I just got hot 'cause I thought you were tryin' to talk smack. If you were just smartassin', than its no thing. Got no beef with with different opinions, I just hate when people start that talking down to other people s**t. If that's not not what your game was, than I apologize, no beef.
The VE tranny's got limited slip, the VG trannys don't. The axles that work with each trannsmission are different. Axles from a VE Max are designed to work in the limited slip tranny, the axles in a VG Max aren't. So if you used a VE tranny, youd have to get the axles specific to the VE limited slip tranny.
To swap your trannsmission, the shops gotta pull the axles anyways. So if you brought the the right ones to them, it would take them exactly NO LONGER, and hence, should be no more expensive (not to mention the others wouldn't fit right). Its just a matter of them using the axles you bring them instead of trying to put the ones they take off back in. Nothing extra for them to do.
If you feel some REAL attachment to your 15 year old car then throw another $2K into it. Personally, if I couldn't do the work myself I'd sell the 89 for whatever you can get, take that and the $2K and buy a 92 Max SE with the 190 hp engine that came with a manual.
I just purchased a 92 SE 5 spd manual w/LSD for $1476. Including the 16" Max wheels and new tires and fixing a few things I now have a total of $2500 into it.
Just my opinion..... and everybody has one.....
As some of may remember, my auto transmission is dying on me and I need a new a tranny so I checked on the org and have found out that converting to a manual could be the cheapest way and most affective mod that I can give my 89 Max SE. I took it to the transmission shop and talked to the guy there about the manual swap and he told me the best thing to do if I were to do the manual swap was to get a wrecked Maxima for cheap that has a good tranny in it and pick it up and take it to the tranny shop and then they can switch in the manual into mine and the auto in mine, out. Now the labor of this is not cheap, $1500 for it and the $500 for the junked Maxima. So i'm looking at about a $2K job when it's all done but my dad and I are gonna check out the junked Max in a few days to see when were gonna pick it up, so it should all be done in a couple of weeks. Thanks for all the help that you guys gave me, it got me headed in the right direction;) .
wher did you find this max
wait for it...
eBay! of all places.....
I just spent another $225 on it for all new struts and a set of lowering springs. Should make for a fun saturday afternoon project. Total cost of vehicle will be upto $2800 after the alignment.
I found it on...
wait for it...
I found it on...
wait for it...
sctludwig
09-01-2022 01:32 PM
03-12-2020 12:06 AM
The Wizard
24
10-01-2015 08:47 PM
