anyone know how to block the EGR
Old Apr 2, 2003 | 12:44 PM
J93MaximSE's Avatar
i was wondering if anybody has done this or if its even worth it. Would you just thread a stud and then screw it on or what. i have some ideas but id like some help if thats ok. cause the search is down which sucks. anyways thanks for your help.
Old Apr 2, 2003 | 02:14 PM
kingrye's Avatar
ya i was going to start athread asking the same question? i herd it gives about 10 hp and better gas mileage
Old Apr 2, 2003 | 02:57 PM
Sudesh's Avatar
i don't think it'll give you any much at all. Running without the egr causes the engine to run hotter, the recycled exhaust is there to reduce emissions and also lower combustion temps. If it improves emissions, I don't think it'll reduce mileage.
I know ALOT of people out there are buying things to block their EGR, but in actuality, it's as simple as plugging one small vacuum hose.
The only possible gains I can see, is lower intake temperatures. If someone can show me Dyno proof that it 'restores' power, then i'll be a believer.
Old Apr 3, 2003 | 12:51 AM
kingrye's Avatar
ok how do u do it
Old Apr 3, 2003 | 02:22 AM
Aaron92SE's Avatar
NWP Engineering.com
I did this and I know it doesn't hurt... so it might help. It definitely doesn't give you 10 HP. I MIGHT give you up to 1 HP. Some DSM guys are seeing 10HP, but not us.
I fabbed up a block plate out of an 18 guage steel plate with holes screwed in it for the studs. I just removed the EGR valve, slid the plate on the studs, then sandwiched the EGR valve back on. Some have put that plate on, put new studs in, then crimped the exhaust tube and plug off the vacuum source. I just blocked it and left it alone. Does the same thing, pretty much.
What the plate does is keep the exhaust gases from going back into the intake. So, it keeps the intake cleaner and cooler. It's a free mod, but I seriously doubt you will get anything more than a couple HP.
I blocked my EGR just b/c I am out of go fast mods. I need more ideas. I would not recommend this unless you are trying to squeeze that extra hundredth of a second out of your Maxima like I am.
Old Apr 3, 2003 | 05:32 AM
J93MaximSE's Avatar
yea, im out of go fast mods to so anything will help. thanks for the info on it.
Old Apr 3, 2003 | 09:38 AM
kingrye's Avatar
yea my friend has a dsm and he told me about it and the 10hp but turbo engines always get more power from mods
Old Apr 3, 2003 | 10:27 AM
Sudesh's Avatar
i dunno guys, the way the EGR operates is very specific. Meaning it only recycles exhaust at certain times, all the other times exhaust doesn't reach your intake because the valve is closed. When you're at the track and you're racing, throughout the whole race the egr valve doesn't open up to allow exhaust recirculation, so you don't gain anything, you don't lose anything by having it blocked. The only time the egr opens is if you're cruising at a nice steady rate.
Old Apr 3, 2003 | 12:57 PM
Aaron92SE's Avatar
NWP Engineering.com
That is exactly right. It is closed at idle and WOT. It comes open at partial cruising throttle. That is exactly why I say that you will not see any gains from doing this. But, you will keep exhaust from going back into your intake... hence the cleaner and cooler intake temps. That is all.
shilov
Feb 19, 2024 09:40 PM
Miket2006
Mar 1, 2021 03:55 AM
howardis
Dec 11, 2019 06:10 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
