Exaust Leak
Old Apr 4, 2003 | 05:51 AM
chrispy's Avatar
Exaust Leak
hey guys, got a problem (sounds familiar from me eh?)
i have an exaust leak, i am thinking it is actually around the headers/gaskets in that area
its getting worse and worse now, unfortunatly i have never done header work before, so any tips would be helpful
btw is it true that on our cars the studs break off for the header nuts?
but the main reason for this post is
What/Why does an exaust leak effect performance of my car, it makes no sense to me, and i would love to know
Chris
91se
Old Apr 4, 2003 | 06:18 AM
Pervis Anathema's Avatar
Re: Exaust Leak
Chris
91se
Put your car on jackstands and start her up. Crawl under the car and listen. WARNING: DO NOT TOUCH THE HOT EXHAUST PIPES. You should be able to hear where the leak is coming from. If you are very careful, you can feel the exhaust leaking out. This is how I found a leak in my resonator and around the flanges that connect the cat to the b-pipe.
The studs that attach your exhaust manifolds to the cylinder heads could be broken. This is common. When you are under the car, you can see the rear manifold and some of the front manifold studs. You could also wait until the engine is cool and feel for missing bolts.
Exhaust leaks lower your back pressure and this has an adverse effect on performance. Also, if you leak in front of the o2 sensor, this can cause an incorrect fuel - air mixture and compound your problem.
Old Apr 4, 2003 | 10:49 AM
lophix's Avatar
Re: Exaust Leak
Chris
91se
wanna know what it is? Studs are broken. Now call up courtesy parts, order the following parts using the following numbers:
http://members.csinet.net/tisch/maxima/studs.htm
Now either get ready to do it yourself and save a lot of cash or pay someone to do it all...it sucks. Also get them all replaced. goodluck.
I'm getting mine done on monday for 145. at least one of the studs snapped during the week.
Old Apr 4, 2003 | 01:30 PM
chrispy's Avatar
you know what,
you guys are the ****
my friend has a mustang 5.0, all the peeps in his forums are dumb/asses, or dumbasses
cool, well i guess i know what i am doign this weekend
thanks
Chris
Old Apr 6, 2003 | 10:34 PM
chrispy's Avatar
sorry to be a PIA
but, unfortunatly since i cant leave my car on jackstands for multiple days
if anyone could give me any pointers specifically on how to remove broken studs?!
Chris
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Mar 12, 2020 12:06 AM
JoshG
51
Sep 21, 2015 10:41 PM
followthadollar
Sep 17, 2015 06:31 PM
