Well i have noticed a little problem i am having, that i noticed today. Well for the past week or so i have been overheating due to a damaged radiator, and today with the help of N34JZ i got my new radiator installed, any how. I drove home to pick up my gurl and opend the hodd to check to make certain that i am not leaking any fluids.. then i start hearing tick every second. like a couple of them in a second. Could it be the adavnce timing that i did about a few months ago that is catching up to me? I went through a drive though and all i hear was tick tick tick..or maybe a clink... and i am worried about it. I have since then retarded my timing back a little. I run 93-94 octane always. and i get about 340 to the 15 gals tank which is better than i used to get. could there be any other problems? the sound seems to be coming from the alternater side near the distributor. at first i thought it was a heat related problem but the radiator is great and working all hoses are tight and good. no leaks.
also side question? i was under my left front tire near the radiator, any ways looking up from underneath, to the right of return line for the radiator there seems to be a big tube that goes to a cannaster the size of a can of coffee.. i pulled out that tube and nothing came out the tube nor from the "cannaster".. what is the purpose of that cannaster? is it a vaccum of some sort?
damn i feel like a friggen newbee.
that is a carbon canister...suppose to absorb gasoline vapors so it won't make a hazardous condition under the hood.
is that ticking when the engine is on or off?
Quote:
true...if when off the ticking could be just the heat expansion or whatever its called when you turn a car off.Originally posted by Fosgate Fan
Quote:
turned on.. goes away the instant i turnt he max off.. but i am leaning to detonation maybe? heat i doubt that. but its coming from the right hand side of the engine bay ear the pulleys and the upper pendulumOriginally posted by DA-MAX
how does that work???? it seems empty anyways.. and such a big sucker and a big tube too...note: canaster is bent/dented due to pot holesOriginally posted by Fosgate Fan
Hey man thats funny Ive noticed the same thing. Ever since my radiator was leaking and had that replaced My VG engine has been ticking slightly sounds like a knocking its weird but I have noticed that ever since the radiator was leaking and I had it replaced its been doign this.
VG as was mentioned above. ARe you sure its the exhaust studs doesn't sound like thats what it could be sounds like its on the top of the engine like a valve or lifter.
i have the same problem.....when i start the car...no tickin'...after i drive 4 awhile....the tickin' starts and goes on until i shut off the car.....it's drivin' me crazy!!!!!!
i have retarded my timing back just before stock setting and the ticking has lessen... i will have to see what is going on with her..
I have the same on my max too, its driving me up the wall
I took her to an automatic trans. guy thinking it was my tranny. He found it to be the belt that goes to the altinator. He put sum lubricant & ticking went away. But it came back after driving for about 30 minutes. Its not a loud ticking, but when I turn down the subs, can hear it!!!!!!!! Sunbody find out. I might go back to him soon
Your problem sounds like the belt is loose or the bearing for the idler pulley is worn out from someone over tightening the belts in the past...I had this problem on my 92 since the guy I got it from used a mechanic that didnt beleive in the correct tension of belts or wasnt paying attention.Originally posted by EdzMax
Quote:
hrrms..its not a screeching sound but more like a taping/ticking.. but that could and does sound like my problem thanksOriginally posted by awsm66
Quote:
I was replying to Edzmax with my post. Yours may be that too but was just telling him that since his was quieted by spraying something on it that it might be the things I listed.Originally posted by crazy4maxima
for me a taping sound is hard to figure out without being in front of it to listen and see where its coming from.
you gave my hopes upOriginally posted by awsm66
Thanks man, I will get that taken care of. She has been runnig very good til that noise started. Still running good.
I heard the noise and It didnt sound like exhaust studs, it wasnt really that loud.
anyway Izzy give me a call so we can finish your interior.
