i need ve engine help
Old Apr 15, 2003 | 12:37 PM
maddmax74's Avatar
i have a 92 superblack se. my ve is hissing and vibrationg hard. i think that a valve is stuck open, cuz when i did a compression test on one cylinder i got less that 30psi of compression. i took it to my dad's shop and he said that i would need to replace the heads and regasket the whole engine, but he doesn't know because the engine is not over heating at all. i'm getting no check engine light and no signs of overheating.
if you got any suggestions i'm all ears
Old Apr 15, 2003 | 02:03 PM
eric93SE's Avatar
I dont know, it could be a lot of things. The only cheap thing that you could try is running a motor flush (follow the directions). Maybe a bad lifter not pumping up.
Use high octane gas, and add some injector cleaner or something else that claims to clean the valves.
Also with the max, you should only use 5W30 not 10W30. Nissan said to do this in one of their technical service bullitens.
Old Apr 15, 2003 | 02:52 PM
Gjohnson's Avatar
Originally posted by eric93SE
Also with the max, you should only use 5W30 not 10W30. Nissan said to do this in one of their technical service bullitens. [/B]
Serriously, Man I just did an oil change on Sunday. And I put in synthetic 10W30. This shouldn't hurt anything, right??
Old Apr 15, 2003 | 03:51 PM
eric93SE's Avatar
nope, you'll be fine. You may want to switch over in the future.
Old Apr 16, 2003 | 11:16 AM
cneary812's Avatar
You may notice that the engine may seem a little sluggish on 10W30 compared to 5W30
James92SE
142
Jan 2, 2024 09:23 AM
homewrecker
Sep 24, 2015 07:01 PM
msellas
Sep 23, 2015 09:16 PM
Socalstillen
Sep 20, 2015 11:46 PM
seesole
Sep 14, 2015 12:38 PM
