What affects the gas mileage?
Old Apr 21, 2003 | 10:19 AM
buzzhd's Avatar
o2 sensor, air filter, gas filter etc?
thanks!
Old Apr 21, 2003 | 10:23 AM
cneary812's Avatar
Re: What affects the gas mileage?
thanks!
yes
Old Apr 21, 2003 | 10:28 AM
buzzhd's Avatar
Re: Re: What affects the gas mileage?
Originally posted by cneary812
yes
yes means I have to change all of them? I don't think I ever replaced o2 sensor...
Old Apr 21, 2003 | 10:31 AM
cneary812's Avatar
Re: Re: Re: What affects the gas mileage?
Well, the way you stated your question you answered it, so if you want a clearer answer next time ask a clearer question.
But to answer your question changing a bad O2 sensor will improve mileage and performance. You may also want to check your flex pipe to see if you have any holes because if you have any holes there then it could give your O2 sensor false readings causing it to malfunction.
Old Apr 21, 2003 | 10:34 AM
buzzhd's Avatar
sorry for my ignorance, what is the flex pipe?
Old Apr 21, 2003 | 10:38 AM
cneary812's Avatar
it is part of yor y-pipe (look under your car and the pipe that hooks to your exhaust manifolds [y-pipe] has a section that has a metal mesh covering on it that flexes with your engine ie flex pipe) and connects to the cat. O2 sensor is next to it in the y-pipe. (well at least on the VE)
Old Apr 21, 2003 | 10:49 AM
buzzhd's Avatar
thanks, Now I remember I had it replaced by the mechanic. What they did was cut the flex pipe and then put a new one by melting...
Old Apr 21, 2003 | 10:51 AM
cneary812's Avatar
if you ever plan on modding this car at all you may want to get an aftermarket y-pipe.
Old Apr 21, 2003 | 11:51 AM
mikekantor's Avatar
I recently discovered a fuel leak near the gas tank on my 93 SE, that decreases fuel efficiency!
Thankfully a hose replacement took care of that.
Old Apr 21, 2003 | 11:53 AM
cneary812's Avatar
yes that can do it as well as the fuel filler pipe. There was a recall on it.
Old Apr 21, 2003 | 12:02 PM
crazy4maxima's Avatar
the obvious issues are alignment, tire pressure, driving style, accessories, traffic , weather, tune up, tire size, weight,wind resistance, gravity, altitude, old parts that lose their specs..
gas octane
there are alot of reasons
Old Apr 21, 2003 | 04:23 PM
mikekantor's Avatar
When I got my Max back in August, changing the charcoal-black air filter gave me an extra 100 miles on the tank!
So the lesson is, don't forget the obvious stuff.
Old Apr 21, 2003 | 04:38 PM
buzzhd's Avatar
so how often do I have to change air filter?
Old Apr 21, 2003 | 04:53 PM
AscendantMax's Avatar
every 30,000 miles.
me, i just take it out and clean and re-oil everytime enough crap builds up on it. good 'ol K&N
Old Apr 22, 2003 | 08:28 AM
chris92's Avatar
Originally posted by Fosgate Fan
every 30,000 miles.
Fosgate Fan, When you installed the K&N filter, did you notice a difference in economy/performance. Is it worth the money?
Old Apr 22, 2003 | 08:45 AM
cneary812's Avatar
If you love your car and plan on keeping it for a while get one. Remember, you can always reuse it on another car or sell it later if you want. You will definately notice a performance increase (POP or CAI) once you remove that restrictive air box. Economy is about the same. You don't need to spend 200 bucks to get it though.
Old Apr 22, 2003 | 10:01 AM
MightyMax13's Avatar
thanks!
Also, and I know that this was mentioned briefly, but I want to emphasize that driving style dramatically changes your mileage. I drove aggressively on my Max until just recently. I now get 100 more miles per tank! Just don't accelerate so fast and drive the limit (thats a hard one I know!). These are two easy things to help improve your mileage.
Old Apr 22, 2003 | 10:25 AM
ThumpinMaxima's Avatar
i find braking hard kills my gas milage...i try now to not use my brakes, when I kno my turns comin i just slow my car down by laying off the accelator--and i can still speed (Thank you V-1)
Old Apr 22, 2003 | 11:16 AM
cneary812's Avatar
You brake around corners????
Old Apr 22, 2003 | 10:37 PM
Maxima NutBag's Avatar
a cracked gas return line can do it too! happened to me.
Old Apr 22, 2003 | 11:26 PM
speeding up and stopping then speeding up etc..
yes i had a breather that runs from my gas tank under the rear left wheel and it had worn out , so everytime i filled up with gas i would lose most of it b.c when i turned off the max, the pressure
in the tank was released and then the tube would expand and the gas would leak from the crack.,. very dangerous, i dint notice til i kept smelling gas and my nose lead me to the rear where i litteraly saw dribbles of gas coming down.. quick fix..
Old Apr 23, 2003 | 10:09 AM
yeah, I kept smelling it in the area near the VIN number under the hood on mine.
Old Apr 23, 2003 | 10:11 AM
DanNY's Avatar
Ad·min·is·tra·tor
fuel lines?
fuel filter?
Old Apr 23, 2003 | 10:18 AM
buzzhd's Avatar
Originally posted by DanNY
fuel lines?
fuel filter?
any idea how to check the fuel lines if there are leaking?
Old Apr 23, 2003 | 10:28 AM
DanNY's Avatar
Ad·min·is·tra·tor
replace what you can see...all of them. the lines are old so they tend to "seep" gas out..hence the smell.
Old Apr 23, 2003 | 10:49 AM
aw89maxSE's Avatar
thanks!
Please don't flame me but how do you change the fuel filter??
Old Apr 23, 2003 | 10:54 AM
DanNY's Avatar
Ad·min·is·tra·tor
small can mounted on the firewall vertically. hose from the bottom...hose coming from the top.
depressureize the gas line 1st...(pulling fuel pump fuse)
loosen 2 clamps (top and bottom)
pull hoses off..
spray yourself w/ gas.
knock over screwdriver while reaching for new filter.
install new filter while paying attention to flow direction (should be an arrow --> flow)
slide hoses back to new filter
tighten clamps
wipe spilled gas from fender
turn the car to "on" position to check for leaks..hear the pump prime the fuel/engine.
go back in your house smelling like gas
Old Apr 23, 2003 | 11:15 AM
DaBoxSE's Avatar
Oh man, I have that problem now! no wonder why mileage is so ishty...I just thought it was a VE thang. How did you fix this??
Old Apr 23, 2003 | 01:40 PM
pull hoses off..
tighten clamps
quick question, are there different flow rates in the fuel filter based on different filter brands?
Old Apr 24, 2003 | 09:52 AM
wasn't the fuel lines, this work was done by the dealership and they inspected the engine and its lines when i took it in.
mclasser
22
Nov 12, 2020 01:58 PM
maxinout93
Oct 31, 2015 02:04 AM
ef9
Oct 4, 2015 08:43 AM
