Clear Out Rear Blinkers?
Re: Clear Out Rear Blinkers?
Originally posted by El Niņo
I know it's done on 4th gens....and I've seen one guy here w/ it. (dragxima)
i want my rear blinkers to match my front hyperwhites....possible?
![Confused](https://maxima.org/forums/images/smilies/confused.gif)
yes its possible just like what pest2001 said just take a needle nose and pull the orange piece out. all i did was just break off the black outline that goes around the orange piece and then i pulled the orange piece out without breakin' it. i've had like this for about 4 years now and i only had one dumb cop
get next to me just to tell me to put amber bulbs in the back which this was 2 months ago down where i use to live in miami, fl.
![NutKick](https://maxima.org/forums/images/smilies/nutkick.gif)
![Slap](https://maxima.org/forums/images/smilies/slap.gif)
hey pest were u the one that told me that u were gettin' the '92 - '94 se gauges??? if so did u already get them??? one more thing what bulbs did u use to make ur gauges light up like that cuz im still tryin' to do that to mine. go to my site so u can check out the new pics i've put up.
yea i got the 92-94 se gauges they work fine the bulbs i have are from www.Autodynamic.com and they are the Polarg Bulbs
and back to the blinkers the cop havent said anything to me about the and where i live we have some pretty mean cops
popppy****! it's not freekin working...i'v managed to break some of the orange lense off...but not all of it. those needle nose pliars arent doing the job....any help?? I need it bad!!!
CAN you take out the assembly and do it? how do you take the the talk light out???
Has anyone tried to take out the amber part out of the front corner lenses before? Is it the same as the rear blinker? Just curious. I guess you could always buy the clear corners...just curious. I already had the clear corners and they keep fogging up? My clears that I purchased are from Taiwan and they just don't offer the same quality as the originals.
Well, first it depends on which 3rd gen you have. 89-91 are much more difficult to do this to because the the orange lense is attached to the back side of the outer lense. 92-94s are easier because the orange lens is just held in by the black trim. You can just beak the little lip on the black trim that holds the orange piece and slide it right out.
It sounds like El Niņo has a 89-91, otherwise he wouldnt have this much trouble. Is your orange piece smooth or is it grooved?
Oh yeah, an a little tip for you guys. You can make your front turn signals look more "Euro" as well. All you do is take out the plastic reflector that is inside the light (carefully). It will look excellent in person, but that also depends on the condition your turn signal lenses are in also.
Here is an example:
Here is an example:
![](http://images.cardomain.com/member_img_a/225000-225999/225235_19_full.jpg)
![+1](https://maxima.org/forums/images/smilies/+1.gif)
i forgot to ask him that question but thanks daboxse for pointin' that out.
doctorpullit
09-10-2015 06:33 PM
ef9
09-05-2015 11:18 PM
