vb mod
Old 04-24-2003, 10:02 PM
white90se's Avatar
vb mod
im sure this has been covered before...but i was just wonderin what exactly is the vb mod...i know it stands for valve body..and it deals wit the tranny but what does it do...and is it worth it..thanks
will
white90se is offline
Old 04-24-2003, 10:52 PM
NWP Engineering.com
Aaron92SE's Avatar
Re: vb mod
VB mod is another name for "shift kit". All it does is make the shifts firmer and more noticable. I bark the tires every time I shift into 2nd while I'm agressive on the throttle. So, it's BY Far worth it to me.
www.maximumtuning.net in LI, NY does the mod for your tranny. This is the ONLY company I would trust with my VB.
Aaron92SE is offline
Old 04-24-2003, 10:56 PM
crazy4maxima's Avatar
Re: Re: vb mod
crazy4maxima is offline
Old 04-24-2003, 10:58 PM
NWP Engineering.com
Aaron92SE's Avatar
Re: Re: Re: vb mod
Originally posted by crazy4maxima
What did you call me?
Old 04-24-2003, 11:08 PM
Re: Re: Re: Re: vb mod
nothing.. yes jeff does great work.. i might be getting a 5spd swap soon.. just avoid the vb altogether
Old 04-25-2003, 06:29 AM
NismoDrew91SE's Avatar
aaron, what exactly did they do with the "shift kit". might look for a place that can do it by me.
NismoDrew91SE is offline
Old 04-25-2003, 02:31 PM
NWP Engineering.com
Aaron92SE's Avatar
Ok, a valve body is a part that is in your automatic tranny. You remove this VB and send it to their shop. They do a recalibration which requires replacing of springs and such in order to raise the fluid pressure... which was cause quick and firm shifts.
Again, I would ONLY trust Maximum Tuning with my VB. If you contact a local tranny shop, they will be like... "oh yeah, I can make your shifts firmer". They will remove your VB and drill some freakin holes in it to allow more fluid through and do some other stuff that is only done with domestic trannies. You get your car back, every gear will be banging into place and then boom. A VB is nothing to mess with.
ONLY trust Maximum Tuning or maybe Level 10.
Old 04-25-2003, 09:12 PM
this is only for automatics?
Old 04-25-2003, 09:30 PM
Back in a 3rd Gen.
Michael's Avatar
Michael is offline
Old 04-25-2003, 09:48 PM
NWP Engineering.com
Aaron92SE's Avatar
That's affirmative!
Old 04-25-2003, 10:07 PM
white90se's Avatar
how long would it take to do the vb mod?? im figurin a few days since it took 3 weeks to rebuild my tranny...just wonderin so i can see how long i will be without max for if i get it done
Old 04-25-2003, 10:35 PM
NWP Engineering.com
Aaron92SE's Avatar
If you are located near Long Island, NY, then it will take you a few hours at most if you drive to Maximum Tuning's shop. If you do it yourself, then you will remove your VB yourself, pack it, ship it, ... overnight.... then they get it, unpack it, modify it, then ship it back,... overnight... then a few days later at the soonest, you will be up and running. At the latest... it could take 6 months like it did me. FYI, do not even think about going with MobileTek aka "Don in Texas". He will give you the shaft like he's done to many people up here. Plus, he doesn't know how to modify any VB except for the VB in the RE4F04A tranny in the 4th gen auto.
Old 04-25-2003, 11:10 PM
white90se's Avatar
a few hours!!! i have some family in L.I....i might just go get this done sooner than i thought
Old 04-25-2003, 11:13 PM
NWP Engineering.com
Aaron92SE's Avatar
Yeap. Call ahead and see if he has any extra valve bodies he can swap in your car. If not, it will take up to 3 hours cause he has to modify your existing VB. www.maximumtuning.net
Old 04-26-2003, 10:30 AM
OG Maxima.org Member
nubiannupe's Avatar
There's a post somewhere on the GD forum for a group deal, I think.
nubiannupe is offline
Old 10-07-2003, 03:00 PM
94M@X's Avatar
How much does the vb mod run at maximum tuning?
94M@X is offline
Old 10-07-2003, 03:11 PM
Gjohnson's Avatar
This is an old thread, but good job doing a search first. If you check the group deal forum there is a group deal that just started for the month of October that you can get in on. Normal price is $375 but they are doing it for $325. (I believe)
Gjohnson is offline
Old 10-07-2003, 03:18 PM
anaximander's Avatar
To the guys who have this mod, what stage are you sporting (there are three), and how does each stage behave? Also, how has this positively or negatively impacted your tranny wealth-being, and were there any other side effects resulting from the recalibration?
anaximander is offline
94M@X's Avatar
I will check there
94M@X is offline
Old 10-07-2003, 03:24 PM
Gjohnson's Avatar
I haven't done this mod myself, but from what I understand it actually prolongs the life of your tranny , because the shifts are faster. I believe Aaron has a tranny cooler with his VB mod, but I'm not sure if this is necessary. Maybe he will enlighten us. Also, you can go to the website from the link that he posted above and it will tell you the different levels and how they behave.
Gjohnson is offline
Old 10-07-2003, 07:57 PM
NWP Engineering.com
Aaron92SE's Avatar
I've done a billion write ups on the org about Maximum Tuning's VB mod. Search for a post by me with "Maximum Tuning" in it. I love it. It's my best mod.
Old 10-08-2003, 09:27 AM
Aaron, what stage do you have, and was there ANY side effect from having this upgrade? I've read the old posts, that's why I waited for a thread like this to pop up to check on the status of the VB modded cars. Sometimes the symptoms take time to show up. It's not a small thing for me to be without a car for 4-5 days, I need reinforced insurance that this mod is as reliable as it gets.
Old 10-08-2003, 06:50 PM
NWP Engineering.com
Aaron92SE's Avatar
Oh I see. No problem. Well this mod has not changed since the firstr day I got it. I did this job, I think, around a year ago. So, ever since, I've been a happy camper. Just tell all your friends to NOT deal with Don Cooper aka MobileTek. I am just making sure you know that.
Call Jeff at Maximum Tuning. He's a great guy and will help you out. I think they are doing a sale right now for around $325.
Oh yeah, almost forgot, I have the middle stage.... 2. It's the streetable version that's not FULL track. Unless you're planning on pushing 500fwhp and having your Maxima as a trailor car, then you don't need Stage 3. Stage 1, is just what the site says, not really for performance. It's more like a Transgo shift kit.
But stage two, I'm barking 1-2 shift all over town with my AWESOME Yoko AVS ES100 17" tires. My last tires... geez, you don't want to know how bad I would bark my tires. 2-3 shift is, OH SO very quick.
You have ABSOLUTELY NOTHING to worry about if you call Maximum Tuning. BTW, you're asking the right guy about a VB mod on a 3rd gen. Have fun!
Old 10-08-2003, 07:10 PM
2 VE's are better than one!
James92SE's Avatar
Who remembers that time Don got:
James92SE is offline
Old 10-08-2003, 11:26 PM
Thank you very much aaron, that's about what I wanted to know. I basically needed first hand experience opinion in regard to the behavior and long-term reliability of a stage. I don't trust anything a website puts up for sales pitches.
lrb6805
09-30-2015 08:12 AM
REDinLV
09-28-2015 12:31 AM
09-27-2015 08:37 AM
zzznightmarezz
09-21-2015 06:32 PM
Quick Reply: vb mod
