Key Broke What can I Do
Hey, the key to my 89 maxima broke, the vehicle has keyless entry how can i find out the code to enter the vehicle once i break into it :~( (where would it be located?) Second what are the steps I need to take to get a new key from nissan? can i do this or Do I need to get the whole car rekeyed. ok and last it is snowing where I am and i couldnt get the car home last night so I parked in a lot where it will get towed on monday any ideas about hotwiring the car so i can move it home till I get a key made?
Thanks For any input D.
Check Kaleb's site: www.kalebonline.com
check the FAQ section.
Hope this helps
You can find the code under the glove box or on the side wall beside the glove box. Then to use it just press clear and enter the code the car should beep a couple of times and then you should type in your own four # code just make one up. Then close your car and try your code this should open the car. If I missed anything this might not work, jsut visit your local dealer and they will tell you how to use the code.
To get new keys just visit a lock smith they should be able to make one for you for about 20 bucks.
