Alarm/electrical issue
Old May 1, 2003 | 06:50 AM
grasshopper's Avatar
Driving on the highway last night and my alarm started going off; horn honking, high beams flashing. When I shut the car off it keeps going and the car will not restart! I tried pulling the alarm and horn fuses, but it did no good. I had to disconnect the battery. Its a 1990 maxima SE, any ideas on the possible issues?
Old May 1, 2003 | 07:03 AM
nubiannupe's Avatar
OG Maxima.org Member
Are you talking about the factory system or an aftermarket system?
Old May 1, 2003 | 07:42 AM
Sorry I should have clarified this is the factory alarm system.
Old May 1, 2003 | 08:11 AM
«§»Craig B«§»'s Avatar
that's really weird, the alarm shouldn't be able to go off while the car is turned on
you can unplug the stock unit and that might help - if you remove the lower dash panel on the drivers side (8 or 9 screws including one hidden in the end under a plastic cover), you'll see a metal box just to the left of the steering column and it should say something like theft warning system on it, try unplugging that
Old May 1, 2003 | 11:24 AM
The worst part is the car won't start. I just had the battery tested at lunch time, its good. Something I didn't try (in my stupidity) was using the key to lock and unlock the car on the driver side. If I yank the Theft warning system the car sould still function normally correct? Lock doors, etc.
Old May 1, 2003 | 01:50 PM
yeah, try disarming it first with the key in the door
everything else should work fine with the alarm disconnected
Old May 1, 2003 | 06:20 PM
Badness's Avatar
close the door lock it with the key then unlock open the door and start.
Mar 12, 2020 12:06 AM
conansriver
Nov 18, 2015 02:46 PM
homewrecker
Sep 24, 2015 07:01 PM
BrandonCause
Sep 14, 2015 10:41 PM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
